Yeh drivabaility will most likely go backwards...thats why i am going to use NAWS, close ratio dog box, high rise double pumper manifold and donuts with cream on top so that when it thits boost it opens a space time continuum :banana:
lol :thumbsup:
here is a pretty crazy rb20 built by OHperformance i had on the dyno the other week the revlimit was 9800 and sounded sweet, real credit to the guys.... :thumbsup: 490hp at the wheels.
peak power at 7350 and they revved it to 9800 jesus!!! go the old short stroker
any spec on engine/turbo?!?
it looks like massive boost not so big turbo... still standard stroke?
Yeh drivabaility will most likely go backwards...thats why i am going to use NAWS, close ratio dog box, high rise double pumper manifold and donuts with cream on top so that when it thits boost it opens a space time continuum :D
hmmm donuts
:P i dont know whats funny, wanting to push a RB20 that far or wanting to use it as a daily???
My old set up was 220ish at the wheels and was a handful on the road at the best of times. The new set up should be 240ish with a more aggressive ramp up and there is no way i plan on using as a daily.
I think you need to read the RB20 results thread or check out Wheezy's tune (was posted my Trent/URAS) late last year with his R31 L2 powered RB20 and you will realise how unrealistic your goals are.
Either way all the best with your endeavours :pirate:
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
