For sale : 1994 R33 skyline Gts-t
Silver, 5 speed
92000km
service every 6000km by Nissan unley / RPM performance centre
using Mobil 1 engine oil
well look after
always garaged
driver side air bag
fully sound deader both door
Nismo 400R front bar
Aftermarket grill
Nissan M spec side skirt
S2 rear wing, boot lock
Tint-a-car fomula 1 Window tint
Greddy Profec E-01 boost controller
Hybird 600x300x76 FMIC
HKS air filter
Jasma approved jap catback exhaust
NGK Iridium spark plug
Xtreme heavy duty clutch good for 250rwkw
Standard rims with bridgestone G2 tyre F: 205 R: 225
Tein HA height adjustable suspension
Bendix ultimate brake pad
Front Strut brace
Whiteline Rear sway bar
R34 GTR Heavy duty starter motor
Boomerang pager alarm system (paid $1200)
Feature:
turbo timer
Remote engine start up
3 point immobilizer
internal microwave sensor
temperature sensor
include option:
auto window lift up
til sensor
$7000 stereo system is optional
audison, Dyn audio
the car is in adelaide
$23000 o.n.o
or swap for a R33 GTR/ S15 plus cash adjustment
https://www.sau.com.au/forums/topic/26131-for-sale-1994-r33-skyline-gts-t/
thanks, i love my car very much and never think of selling it.
but thanks parents, i got the chance to afford a GTR.
i bought the car last year nov which is nearly stock, going back home country for summer holiday(3 months), and start mod it when i am back at end of feb, so most of the mod are only 1/2 year old!!!
without stereo, but the sound deader will stay;)
i am happy to take the intercooler and boost controller off for lower selling price(i want to keep it for my GT-R).
the boost controller itself worth over $1000!
also happy to seprate buyer can swap me their standard part
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
