  • Replies 207
Neons sound good... I am installing an X-box / TV screen / subs / amp / cd player into my car shortly (After timing chain is fixed) and might be after a Small green Neon for above the Xbox in the car... how much for like a 30 cm neon?
MELV,
Thanks for the replacements.... Got them all installed and working today and they look awsome. I will get some photos and post them up soon.
Excelent. good luck with the install. please dont forget to send a photo.
CHEARS
MELV
Hi Melv
Just read through all the posts on this thread and am definately considering doing business with you. Can you send some pics of the aqua and blue through to [email protected] please mate.
Cheers
hey mate if u could send me some pics of blue neons and red if u have them that'd be great, if u can send any others aswell it would be appreciated, i just need to make up my mind about about what colours i want, cheers.
[email protected]
hay melv , got a bright blue line , woundering if you can do yellow as no-one has mentioned it yet , and I am going for a yel/blu theme ? if not pics of other kolors pls to [email protected] . will be in bris vagas in a few weeks so can p/u or come around for a look at least
jaqule, mate we do offer a yellow but the glass is diffrent from the normal (blue green purple red aqua etc) its very very brittle and will break alot easyer and its not as bright. i will send you a email of a few pics i have taken of diffrent colours etc.
Melv,,,I stickied your thread cause I thought it would help everybody who wanted neon's. Now I would like you a donate a bit of your profits to keep this place going. If you can,,,then please contact PranK.
Thanks
Neil.
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
