I put some height adjustable suspension in my car on the weekend. The old suspension was low - 330mm at the front. I'm now thinking 340 front, 330 rear. What are you guys running? The car sees a bit of track and already has plenty of adjustable arms/bushes to get the geometry right.
Have a look at the roll centre.
With the GTST I find if I go any lower than ~345-350mm it looks as if the lower control arms start to level with the cross member (up front) and then if I push it to 340mm the cross member is noticably lower than the lower control arms.
Dare say its approximately the same with the R32 GTR.
I've got the front of mine at 345 and rear at 350 as when the rear is slightly lower it tends to understeer and simply feels a little nicer with it sitting just that little bit higher.
From what I've been told don't go too low as it messes with the roll centre.
Edited by TheRogue
My understanding is that the rear should be 10mm lower; See Here;
"Rake angle (or front to rear balance) plays a huge part in how the GT-R corners. Lowering overall by 1" as you say is OK, but you must make sure you keep the front (as measured from the centre of the wheel to the arch) is around 10mm higher than the rear. If you have a neutral (or worse rear elevated) rake the car will understeer like a bitch.
And IIRC SK used to quote a 10mm difference. Sort of makes sense as you'd expect the front wheel arches to be cut higher in the guard to give more clearance to the wheels that steer....
Many people forget that as the lower cross member lowers it can badly affect the rear tow and cause a raft of issues.
At stock height for example. If the wheel raises or lowers the rear tow could for example change by 1 degree in and out as the wheel rises and falls.
If you lower the car to extremes you will probably get assymetrical tow changes causing crappy bump steer performance.
The best way to lower the car without causing this is, lower suspension arms like the Ikeya items which lower the bottom ball joint leaving the suspension geometry as per stock
Front 355
Rear 345
Try and get about 6 to 6.5 front caster
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
