hey guys here is my car and wondering what you think i should do next. ?
carbon fibre bonnett?
lower car?
front bumper of front lip??
heres a pic of the car now. just wondering what your oppinions are, massive storm coming here foxtel out so now im left to entertain myself on here lol
https://www.sau.com.au/forums/topic/261363-what-to-do-next/
Looks nice like that, i would spend my money on brakes or handling or performance.
carbon fibre bonnett? Defect
lower car? scrapes on speedhumps and steep driveways and effects handling
front bumper of front lip?? I smashed my 400R on a driveway(gone back to stock)
Just my 2 cents.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4480759
i would say do what u want to do.........no one else is driving the car but you so who cares what anyone else thinks?
i started off with exhaust/rims/body kit/ and went from there.........its ur car u do what u feel is best.....
just my 2 cents
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4480782
some nismo clear side indicators? only like 80 bucks but i would spray the outer section white instead of leavin it black like a majority of ppl.
if ya going for styling looks (obviously cause u put it in this section lol) how bout some interior stuff?
how are ur wipers looking? mine looked a lil worse for wear so i sprayed em a matte black. made the front look a lil newer. but i guess only to me as i was the only one that knew i did it. lil things like that i like doing to brighten the car up a bit. anyway im rambling.
just have a close look around ur car and things u might wanna change, write them down and think of a way to do it. even the smallest things changed can make u feel better about the looks of ur car
Edited by SLY-25T
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481277
yeh i was thinking the exact same thing the other day mate, was looking at my wipers and was thnking that they need a touch up hey. looking a bit worse for wear,. but yeh i guess i would be the only one that would notice it but would look better to me as im everyday noticing it.
clear indicators one step a head of ya hey haha waiting for them to arrive in the mail. yeh thats a good idea about spraying white,will keep that in mind for sure thanks mate.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481296
another thing i did (but failed lol) was spray the rubbers around the windows. saned a few bits, taped it all up and sprayed fine. next day car was in sun for a while and all parts i didnt sand properly had gone wet again cause it didnt grab properly :) the B pillar garnish looks alot better though. will have to do a proper job. just used the same stuff as i did the wipers with.
so check over your car for bits that could use a touch up with some paint and give it a go.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481382
got nsmo side indicators on now
and also painted the wipers black agaiin, looks way better like brand new again haha.
yeh paint the indicators white around the outside ya reckon. anyone got a pic of this done>? hows it look?
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4498235
cliff, like above, just get an orange LED. looks nice. and with the painting of the outside, id say mask off light area and could find some close matching spray paint. havent seen any done yet so might look a bit diff :D
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4499328
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
