Where can you get Forged RB25Det pistons Cheaply and fast!HELP!
Originally posted by Steve-SST
I have a large order due late next week but not for $900.
Steve,
Sorry should have said that the $900 was for cast ones, without rings. I am looking for a forged set as close to $900 as possible, more importantly is getting the sooner rather than cheaper because the insurance co. is paying.
Butters,
The engine was damaged in the accident as the timing belt was cut and valves bounced off the top of pistons. The dodgy insurance company wanted to just replace one piston and leave it at that. I explained to them that the other pistons must have also recieved damage and addtional stress since the engine was under load and doing several thou rpm. I am insisting they also replace the camshafts and valves since the forced of contact on the piston is transfered through to the cam lobe. I want nothing less than a proper engine rebuild and thats just what I am getting.
While I think of it whats the damage on a set of mild camshafts to suit & where do you get them from?
Originally posted by GTS-t VSPEC
$900? I doubt you'll get them for that, even at trade price, unless there made in Hong Kong;)
Nah true that.
Rocket industries flog Arias for about $1280ex , on low volume purchases (like just one set) pricing is alot keener if you setup an account or buy regularly. They come with rings and pins as well though. Have to be the best forged piston spec I've seen and they are the cheapest.
thats crap eh.
Damn insurance companies.
Friend of mine is going through simular thing. Her water pumped died. which caused the engine to over heat and kill the heads.
The waranty is only covering the water pump replacement. She has to fork $$$ for the heads to be done.
They claim the only cover the faulty part. Claim if she had stopped it straight away, no damage would have been done.
I reckon thats pretty rough.
INSURANCE companies are maggots
I fought tooth and nail with my assessor, hi manager,etc. I ended up going to the secutary of complaints.. and guess what he was a tosser as well.
So in the end you cant win.
Daniel
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
