I know, its not for everyone. Some will like, others will hate. But here is the latest modification to the 260RS.
Angle eyes and LED indicators.
One of the reasons for the LED indicators was I didn't like the large orange indicator mounted into the front bar next to the front mount intercooler. With the LED indicators, I've managed to remove these large orange indicators entirely. Maybe I will fill the holes with some black mesh? Still to decide ...
The angle eyes act as the park lights now and I like the overall effect its created.
Just trying to create something different from the other Stagea's out there ....
https://www.sau.com.au/forums/topic/261372-latest-edition-to-the-stag/
you seen that vid on youtube...
the guys got a whole led setup for his tail lights. must have some crazy control panel inside the car to control it.
http://www.youtube.com/watch?v=XqfS37GGFhk...feature=related <---- just saw that one ....
Yeah mate I almost bought an identical set, only thing was the guy wanted OVER $2000+ Aus dollars for them. I mean I like them, but I dont like them THAT much :verymad:
  • 3 months later...
Yeah mate I almost bought an identical set, only thing was the guy wanted OVER $2000+ Aus dollars for them. I mean I like them, but I dont like them THAT much :)
im looking for those led tail lights. any chance you can give me a link or a contact on where to get them??
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
