I know, its not for everyone. Some will like, others will hate. But here is the latest modification to the 260RS.
Angle eyes and LED indicators.
One of the reasons for the LED indicators was I didn't like the large orange indicator mounted into the front bar next to the front mount intercooler. With the LED indicators, I've managed to remove these large orange indicators entirely. Maybe I will fill the holes with some black mesh? Still to decide ...
The angle eyes act as the park lights now and I like the overall effect its created.
Just trying to create something different from the other Stagea's out there ....
https://www.sau.com.au/forums/topic/261372-latest-edition-to-the-stag/
you seen that vid on youtube...
the guys got a whole led setup for his tail lights. must have some crazy control panel inside the car to control it.
http://www.youtube.com/watch?v=XqfS37GGFhk...feature=related <---- just saw that one ....
Yeah mate I almost bought an identical set, only thing was the guy wanted OVER $2000+ Aus dollars for them. I mean I like them, but I dont like them THAT much :verymad:
  • 3 months later...
Yeah mate I almost bought an identical set, only thing was the guy wanted OVER $2000+ Aus dollars for them. I mean I like them, but I dont like them THAT much :)
im looking for those led tail lights. any chance you can give me a link or a contact on where to get them??
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
