  • Replies 91
more jackings .. Good to see that were a following the U.S trend now we have to worry about which street we drive in and weather or not we have quick track or not along with all the other day to day issues, great...! I guess in the end the one with least to loose wins. had a mate that it happened to he disabled the door from the outside (passenger) not that its much of solution but at least it will make it that much harder on an attempt.
A question i have though, if a person is involved in a carjacking where life is at risk, and you do have full insurance...would handing the keys over to avoid harm result in voiding your insurance?
i mean, technically, your handing your keys away, im sure some insurance companies will see it this way, and would be nearly as bad as the car jackers themselves.
you could also set one kind of timer in your car, something that runs seperate to everything else. something as simple as a timer that unless you hit a button once you start the car will only run for two minuttes before shutting off automatically. wouldnt be too hard to set up.
sh*t this is ridiculous. I plan on bringing my car up from adelaide to get away from all the mass-defecting-obsessed police over there, only to face theives over here! Jees, My cars just been completely "cosmetically improved" and stands out like a donkeys sack attached to a small dog.
Is it just GTRs that are the main skyline target? or GTSt's too?
"shows how badly these WRX drivers want a skyline "
"the big question is, how on earth did a WRX catch a GTR in the first place "
Thats gold, Jerry! GOLD!!!!!!!:D :D
do you think the police would fine or charge you if they found you carrying a small batton just inside the door, say if you use the excuse about "there have been alot of car jackings lately and you guys aren't always around when needed...."
how do you think that would go down?
Mr R32 M-Spec - I think it'd be confiscated and you'd be fined. Plus with that excuse you'd get done for intent to do battery, not self defence.
I think the best alternative for a battery device which is legal is a small fire extinguisher (chemical type) - you spray the bastards with the chemical and while they're temporarily "blinded" you beat the crap out of them with the canister end. Best of all it's legal because they're legal to carry (Just make sure they're in an easy spot to access.)
Just get a Maglite.
Carby cleaner works better than mace - so I have heard. .....
But I would never encourage violence or vigalantism towards armed Car Jackers. Best to to hand over the keys and let the police & tracker companies handle the rest. That way you just lose your car and not your life.
I think you have to make a judgement call based on how your car is being jacked/stolen. If it's a lone guy with some sort of hand tool threatening you through the window, then I'd say your car would be worth fighting for. But if he has a gun or if there is a bunch of them, might be better all round just to give it up. Try some stealthy tricks like already mentioned, like taking the keys out and hitting the panic alarm once you've legged it away a bit.
Of course, if you discover someone breaking into your car, a king hit and a trip to hospital (for them) is in order :P
Oh, I was thinking of it you came across them in a car park or the like. I think if I busted someone breaking into my garage, I would get them arrested and then move houses asap afterwards. One of the advantages of renting I guess.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
