Hey everyone,
Not sure if this has been covered before but I am interested to see what people think of these two turbos and how they rate for value for money.
To my understanding a R34 highflow can make up to 260 rwkw with all the supporting mods on a RB25 with good response.
And a 2835 pro s can make safe power up to 270 rwkw with all supporting mods with good response aswell.
Now the punchline, R34 highflows go for around $1000 second hand (obviously double brand new) and the 2835 for over 3200 on Slide.
So thats almost similiar power for 1/3 of the price second hand!
Does anyone have of there own experiences to shed some light on this situation? I would love to hear how either of these turbos drive and what you think is the better buy.
Thanks,
Mike
a 2835 is good for more than that... many people have around 280rwkw...
i have 270rwkw on pulp and that's with an exhaust cam gear robbing my top end for a meatier bottom
the 2835 has great response (i'm @ 18psi by 3500)
on e85 i'm making 311rwkw @ 18psi.
personally if i had to buy it on today's prices i'd go a garrett 3071
what about that hypergear hiflow? It's not BB but it uses garett internals and new only costs $900 ? something to consider if on a tight budget ... that extra money can buy a lot of nice supporting mods :)
I guess it depends on the sort of rear housing that you do have. Some of RB25det Neos was released with .63 rear. The high flow can get even more power if that is the case.
If not then better off getting a GT2835Pro S.
Edited by hypergear
Good thread Michael, i will be watching this one as i will be looking an an upgraded turbo quite soon. But as there are so many options its tough to decide.....
But as lots of people say on here, do it once, do it right. So thinking of getting a turbo that is not MAXXED out, just for piece of mind.
But why a 3071? Sure a great turbo, but i plan to track my Rb25 and want to keep it fairly reliable so the 300rwkw a 3071 would easily give me would go to waste on a standard motor.
the HKS 2835ProS is a 56mm compressor with custom HKS turbine cover and 71mm 56 trim compressor, a GT3071 is (usually nowadays) a 60mm turbine in a garrett turbine housing and a 71mm 56 trim compressor. both 450hp compressors (more or less)
sounds pretty similar eh. the HKS turbine covers are a nice bit of kit but they cost a lot more money.
the hi-flows usually use a very similar 450hp compressor but the turbine is the probably the biggest limiting factor due to the factory turbine housing.
for 300rwkw then GT3076 is the most likely reliable way of getting there for a reasonable price.
But is it really worth it getting a 3071 or a 2835 when you can have a second hand highflow for 1/3 of the price and only 20kw less?
Is there that much of a difference in feel between these turbos hence the much higher price tag?
i think you are comparing three glasses of mainstream beer and wondering which one is better.
they are all good choices (assuming 2nd hand hi-flow is in good nick).
they all taste about the same.
they all get the job done.
the biggest issue is that the hi-flow may make a little less power up top (or it may not) but should be pretty line ball down low and mid BUT it should bolt straight on. factory oil, water lines, intake and dump pipe all bolt back on exactly.
the GT3071 and HKS units will have various levels of fiddling around to get it fitted and running potentially adding to the expense.
so if you are happy with 240-250rwkw and save >$1000 then it is hard to argue for spending more money when you will probably spend less than 5% of your time on WOT.
there are heaps of threads on these turbos so it is going to come down to a personal choice.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
