I'm after anyone running a HKS GT-RS on an RB25DET, (genuine HKS kit, not a Garret equivalent) to post up their dyno graphs.
Specifically their boost graphs.
I'm running one on my car and have been for some time, but only recently 'finished' the package off with injectors and a Z32 AFM...
It made 253rwkw on 18psi, but boost isn't holding in the top end, which is why I'm after other's GT-RS graphs, as well as any similar experience with boost not holding, and how you overcame it if you did...
My car has all the supporting mods, with most mods being Jap brands and not cheap chinese copies.
Thanks in advance :)
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/
do you have an electronic boost controller? Honestly every dyno graph I've seen I always seem to see the boost pressure starting to drop off at the top end mine included. My tuner said that it's very common for skylines. I'm sure someone will disagree and probably has more useful advice.
How much is the boost dropping off and how quickly ? Post up your dyno graph if you have it handy
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4481180
I am interested in this as mine is also dropping off albeit on GTSS on a 26, but the same question ponders, I am going to replace the EVC6 to see if it is defective failing which I will wind up the HKS actuators to set them at 14 psi (currently at 11) so the evc only has to hold 4 psi above the actuator pressure rather than 7.
I hit and about 18ish for say 1,000 rpm and then as with the above, it tapers off a couple of psi down to low 16's.
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4481941
I have the same problem as well, it peaks at like 19psi then falls to like 17psi, no matter how much I stuff around with the duty cycle settings.
I thought my BOV was leaky, so I put a rubber sheet between the stock BOV & the cross over pipe, no difference. I thought it was the actuator, but after seeing dyno graphs, it seems to be the norm.
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4482166
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
