Hey guys,
Just thought id share my happiness of my car finally being back on the road :)
Basically almost 2 years ago my my forged engine unexpectedly blew up most likely due to a Bee R Rev Limiter I had installed. Since then the car was at Created Motorsports getting a forged rebuild done with a change of turbo - HKS 25-40 and a few additions including an alluminium radiator, engine oil cooler & splitfire coilpacks. The car has now been run in and made a strong/responsive 262kws at the wheels which is loads of fun for a street/track drift car.
Since the car was off the road for over a year i got a little excited and thought id bring it back with a bang. So i got rid of the black & painted it Ferarri red as ive never seen a red r33 before & thought it would go much better with the black works :). The paint job was done by Kila Body Works who did a fantastic job.
Anyway i wont continue draining your lives, hope you like the pics.
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/261413-my-skyline-is-finally-back/
i love this car :) to appreciate it you really have to hear the screamer... normally i dont like them, but deans sounds unbeleivable!
congrats on a clean car dean! i know you've been lovin it!
Thanks guys.
Yeah its awesome havin it back. I had little fun bangers for the time being while the car was off the road to keep me occupied but wasnt the same. Was the main reason why i took the car to the sandown drift practise day... so i could get the feel of the car again. I got a little too used to the R31's & VN's while it was gone lol.
As for the wing, yes thats a definate! & a nice pair of red or black recaro's would be awesome.
What do you guys think about a carbon fibre rear stealth wing on my car like hamish's? Im trying to decide whether to go for the carbon fibre one to suit the bonnet or just get a fibre glass one & colour code it to the car... Think ill do some photoshop work to decide.... :P
Heres a couple more decent shots...
Oh and the bonnet isnt carbon fibre... im waiting to find the right one. Thats why i didnt bother painting it and left it black for the time being.
Edited by Dean_HR31
very nice hopefully i'll be able to afford similar rims as well! i love meisters!
ever thought about doing carbon fibre boot with the drift lip ?
saw a white evo 6 the other night with black boot and wing blade looked good.
and if it's ok could i get the specs of the rims i.e. width and offset?
Edited by TaKz
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
