Discount Brake Disc And Flywheel Machining Service
boostn32
 Share
Hi as of this saturday 31st i will be offering a disc brake/drum brake and flywheel machinging on weekends and after hours (6pm) during
the week. Im a qualified Heavy Vehicle Mechanic for a world leading truck company.
car disc barkes $10 per disc rrp$15
car drum barkes $10 per drum rrp$15
flywheels $35 rrp$50
i can also do full brake and clutch replacements.
Im located at Upper Coomera on the Gold Coast
00401805955 Luke
  • 1 month later...
yeah i like to help out other members, but with a new machine costing 12k it might be a while off. :blink:
also disc brake prices are now $12 sorry but cutting tips have gone through the roof, stupid economy. either way still the cheapest around.
nice brother, we appreciate ur hospitality :) ... mm upper coomera ay :blink: me too!! man.. any chance you could check out a nismo 2way i got.. needs to be welded (i think).. haha would you take a look at it for me?? <3333333333333333333333333333333333333333333333
throw me a txt man
0401 401 949
regards JEZ!
Edited by 32JEZ
Hey buddy, I got an r33 which needs the spigot and thrust bearings done so I'm thinking just to get a clutch kit and do everything at the same time. If I supply the clutch, how much would you be able to fit it for me? Cheers!!
will do a 25 box in and out with full cluch kit replaced. including spigot and throw out $180, i may or may not beable to machine your flywheel
myself, waiting on new machine. if i can do it its + $35 if not i can arrange it for + $50
  • 3 weeks later...
Thanks for sorting out my brake discs and pads for me luke reasonable price and great job done.i was lucky i didnt go to the workshop that quoted me $44 to machine one disc and $174 for labour :) .. oh yeah they are running quiet now.. still havent got the chance to do some hard braking... haha..
will be looking forward to your hicas bar... wanted to chat longer that day but didnt have time.. once again great prices... :ermm: worth the trip from brissy..
You in the market for doing seals on brake calipers while you machine the rotors? Maybe it's not your thing but I thought I'd ask. I hate brake shops, always trying to rip a guy off !!!
DAS KAMU pm sent
simple tool, yes i can rebuild your brake calipers, it is time consuming due to cleaning them out and fitting all new seals,
but its well worth doing, i think most people would be surprised as to the amount of dirt/sluge that builds up in the calipers
and around the pistons. you will need to leave your car with me for a few hours to do the job. pm sent out laying charge details.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
