hi id like an opinion from the experts, here'e my problem.
I own a 1996 series 2 skyline with forged pistons, methanol injection, custom plenum, gtr fuel pump, garrett gt3076r on custom manifold, aem fic, stock injectors , external wastegate set to 10psi.
about two months ago i came across a "swat" ecu from an r32 gtr and decided to give it a try.
members on the forum advised me of the necessary conversion to make the ecu work ( add additional o2, additional maf, air temp sensor, disconnect vct.), the car ran fine after adjusting the cold start, 12psi by about 3200rpm and with the motor reving to 8500rpm i have about 5000rpm of boost.
the car feels great on the street, but i went to the local tracks here in Nassau Bahamas and my best time after 5 runs was a 9.4 in the 1/8 mile on 10psi. With my stock ecu I run a consistant 9.1 with the same psi. I race on maxis va 1 street tires nothing special so i expect alot of wheel spin. I think however with the more agressive time curve in the "swat" ecu I should have lowered my elapsed time.
the car has alot of power down low, so i started to attribute the lower ET to wheel spin, but whilse racing a stock series one skyline on 14psi ( stock ecu, stock turbo) i noticed he was able to pull away from in third gear. after abit of seat time today, i realized the car looses power above 6000rpm, any opinions on what could contribute to the loss in power. the afr are consistantly around 12.2 and the boost is holding so i dont believe its a leak problem, the only thing off is the power.
any ideas
https://www.sau.com.au/forums/topic/261443-loss-of-power-above-6000-rpm/
