There are certainly other options out there, but not many.
For the MY11+ GTR with the 390mm front rotors you only really have Alcon and AP rotors as a direct rotor replacement, though these still require new hats.
The 390mm fronts are better than the 380s on the MY09-10, but still prone to cracking, like this after a couple of days on track:
  • Replies 151
Posted Images
^ same as the r32 rotors - crack across the cross drill section.
i noticed that the alcon & ap rotors are slotted for the r35, so why have nissan cross drilled rotors from factory? you wonder if this was a marketing ploy for replacement purposes / ongoing business (similar to that of the iphone with glass screen which does not bounce well)
I wouldn't worry about forking out $$$$$$ for rotors. When mine are done and dusted, I'll be going with DBA 5000's.
Guys on NAGTROC have said nothing but positives, I've used DBA's on my Subaru STi's for track and daily work with no issues what so ever.
http://www.nagtroc.org/forums/index.php?/topic/66648-dba-5000-series-rotor-ring-set/
http://www.nagtroc.o...rotor-ring-set/
DBA's are great & I use them as well. $325 per rotor makes it almost 90% cheaper than the oem's :)
Australia have developed A LOT of good upgrade parts for the legacy GTR's & seems to be the same trend for the R35
I don't know why they are drilled, the holes fill up with brake dust after a few track sessions anyway.
I asked DBA about 390mm rotors a few months ago, they were waiting for an OEM sample to work with...So doesn't sound like they will be available anytime soon, but I will certainly get them when I can.
Don't ask the Aus DBA boys, you gotta go DBAusa.com to get the good stuff. They make them already, this is direct from their USA website.. Mind you these fit up to Feb 2011 build cars.. Anything after nada!
Front Rotor
DBA 52320BLKS DBA 2 req
DBA 52320GLDXS DBA 2 req
DBA 52322.1S DBA 2 req
Replacement ring to suit OE hat DBA52322.1XS DBA 2 req
Rear Rotor
DBA 52321BLKS DBA 2 req
DBA 52321GLDXS DBA 2 req
DBA 52323.1S DBA 2 req
Replacement ring to suit OE hat DBA 52323.1XS DBA 2 req
Edited by Wardski
why wouldn't you go with the AP's? i've used quite a few sets with nil issues. Not trying to cause a shytestorm but nearly every DBA i've used (admit on other cars) have warped pretty quickly. Might be the way it's bedded in (my fault perhaps) but from my perspective the DBA's are more fragile in that sense. I wouldn't buy them, at least not for track. For the street, sure.
DBA rotors can be hit n miss, but this was more like 5 years ago. I've had about 5 sets on the STi, and not one have had any issues - other than wearing down too fast - but that was probably more my fault than anything else :whistling:
  • 1 month later...
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
