Have had this problem since I got the car and it was stock as a rock and its still the same after all these mod's !!! The engine misses with any more than 12psi boost. This week all the following gear went in-
t3/t4, FMIC,PFC,Adj Fuel Reg,Big Fuel pump,z32 afm,new plugs(copper-correct gap) and we tested every coil pack with a known good item. STILL MISSING. It runs like a dream until we go over 12psi. I have been told it could be the crank angle sensor(dry solder joints??) but we ran out of dyno time and crank angle sensors. I hope I have given enough details for some of the SA GURU's to offer some idea's.
Cheers
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/
SK - AHA!! I HOPED YOU WOULD DROP IN, IT'S GOT 7'S WITH .8MM GAP. PREVIOUS TO THESE COPPERS WE TRIED IRIDIUMS ETC AT MANY GAPS AND HEAT RANGES WITH NO LUCK.
JTECH- ITS GOT A POWER FC SO NO BOOST/FUEL CUT ISSUES
I KNOW THIS SYMPTOM HAS BEEN COVERED TO DEATH BUT I THINK MY PARTICULAR PROB COULD BE AN ODD ONE.......MMMMMMMM
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554211
i have exactly the same problem over 12psi!!!!!!!! its very annoying so i just wind the boost down for now! and ive also done the whole experimenting with plugs, but nothing helped.
i have found that it happens alot more before full operating temp.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554638
Have you actually set a boost cut level. Mine is set at 1.46bar If i just touch up to it in 1st or 2nd i get a misfire if i hit it hard under full load in 4th i get complete ignition cut until the revs are back down to zero then ig comes back on and i can restart.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554647
Just a stab in the dark, but a mate had the same thing.
He regapped his plugs from 0.8 to 0.74 and it worked a treat - miss fire totally gone..
It's hard to believe that 0.06 mm made that much of a difference, but in his case it made the world of difference !!
Good luck.
J
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554660
Stevo is it a series 1, 1.5 or 2? if its a series 1 have you tried another igniter module? Seems like you've replaced all the normal problem parts. This sounds electrical and it"s boost related so try another MAP sensor. Hope your'e monitoring vitals on the dyno like fuel pressure, new parts can be faulty and you need to know that all your bases are covered. Hope this helps Good luck.. :(
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555946
Common Stevo, do the leak down test, it will rule out internal problems. Then you can confidently say its external and swap bits over. We find the best way is to get another car same model and swap them, one by one.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555975
Originally posted by DAMQIK GTS-T
Well I wasn't losing power that I new of but on the dyno @ 6000rpm and @ 14psi the hose sucked closed  the mixtures went really lean, (map senced ecu) those rubber hoses to the turbo are ONLY good for stock boost.
I'm not saying it's the problem but at least check it.
Lucky your car was on the dyno when it happened, you dont get too many chances with lean mixtures at load.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-556180
Thanks boys! Leakdown down test next, then igniter module(its a series one). It has a new fuel filter and monitired fuel pressure on dyno OK. No rubber hose left on turbo inlet to crush. Probably look at the injectors next. Hey SK, when you used this fuel setup as an alternative to getting bigger injectors, could you get a nice smoooth idle? Some times (only first tune) it can be OK then it gets a bit grumpy/rough. Dripping/dirty injectors?.........will keep you updated guys.
Thanks for the input,
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557096
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557113
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
