Have had this problem since I got the car and it was stock as a rock and its still the same after all these mod's !!! The engine misses with any more than 12psi boost. This week all the following gear went in-
t3/t4, FMIC,PFC,Adj Fuel Reg,Big Fuel pump,z32 afm,new plugs(copper-correct gap) and we tested every coil pack with a known good item. STILL MISSING. It runs like a dream until we go over 12psi. I have been told it could be the crank angle sensor(dry solder joints??) but we ran out of dyno time and crank angle sensors. I hope I have given enough details for some of the SA GURU's to offer some idea's.
Cheers
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/
SK - AHA!! I HOPED YOU WOULD DROP IN, IT'S GOT 7'S WITH .8MM GAP. PREVIOUS TO THESE COPPERS WE TRIED IRIDIUMS ETC AT MANY GAPS AND HEAT RANGES WITH NO LUCK.
JTECH- ITS GOT A POWER FC SO NO BOOST/FUEL CUT ISSUES
I KNOW THIS SYMPTOM HAS BEEN COVERED TO DEATH BUT I THINK MY PARTICULAR PROB COULD BE AN ODD ONE.......MMMMMMMM
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554211
i have exactly the same problem over 12psi!!!!!!!! its very annoying so i just wind the boost down for now! and ive also done the whole experimenting with plugs, but nothing helped.
i have found that it happens alot more before full operating temp.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554638
Have you actually set a boost cut level. Mine is set at 1.46bar If i just touch up to it in 1st or 2nd i get a misfire if i hit it hard under full load in 4th i get complete ignition cut until the revs are back down to zero then ig comes back on and i can restart.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554647
Just a stab in the dark, but a mate had the same thing.
He regapped his plugs from 0.8 to 0.74 and it worked a treat - miss fire totally gone..
It's hard to believe that 0.06 mm made that much of a difference, but in his case it made the world of difference !!
Good luck.
J
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554660
Stevo is it a series 1, 1.5 or 2? if its a series 1 have you tried another igniter module? Seems like you've replaced all the normal problem parts. This sounds electrical and it"s boost related so try another MAP sensor. Hope your'e monitoring vitals on the dyno like fuel pressure, new parts can be faulty and you need to know that all your bases are covered. Hope this helps Good luck.. :(
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555946
Common Stevo, do the leak down test, it will rule out internal problems. Then you can confidently say its external and swap bits over. We find the best way is to get another car same model and swap them, one by one.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555975
Originally posted by DAMQIK GTS-T
Well I wasn't losing power that I new of but on the dyno @ 6000rpm and @ 14psi the hose sucked closed  the mixtures went really lean, (map senced ecu) those rubber hoses to the turbo are ONLY good for stock boost.
I'm not saying it's the problem but at least check it.
Lucky your car was on the dyno when it happened, you dont get too many chances with lean mixtures at load.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-556180
Thanks boys! Leakdown down test next, then igniter module(its a series one). It has a new fuel filter and monitired fuel pressure on dyno OK. No rubber hose left on turbo inlet to crush. Probably look at the injectors next. Hey SK, when you used this fuel setup as an alternative to getting bigger injectors, could you get a nice smoooth idle? Some times (only first tune) it can be OK then it gets a bit grumpy/rough. Dripping/dirty injectors?.........will keep you updated guys.
Thanks for the input,
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557096
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557113
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
