I'm strongly sonsidering putting an RB25 Det into my Datsun Syyline. What I want to know is what 1/4 mile times do you do in a stock or semi stock ( maybe turbo upgrade) skyline with RB25DET.
Also what is the kerb weight of your car, mine being 1260 kg I'm trying to get an idea of power to weight ratio. Cheers
https://www.sau.com.au/forums/topic/261466-rb25det-how-quick-and-what-weight/
  • Replies 46
hay mate .. i done 13.9 with my r33 .. full zorst , pod , cooler and a clutch .....
donno if thats good or not but i was happy ...
now im thinknig of getting a hi-flow turbo , safc and i got a bosch fuel pump so should do a lil better ..
The quickest time I've seen with a completely stock R33 is 13.4, and I've seen high 12's with mods but stock turbo. Weight of an R33 is around 1470kgs, so with lighter weight you could expect better results, assuming you can get traction etc.
Where did you see it do a 13.4? R34 GTR's only do a 13.7 pass or so it says...
Almost stock R32 GTR's have done high 12's, so who's driving the R34 :thumbsup:
It's all about 60' times, if you can get your car to hook up properly with a sub 2.0 60', then your in with a shot of a decent ET. The MPH on a stock Skyline is pretty low.
So true
So true
Post #10
http://www.skylinesaustralia.com/forums/Be...-B-t260897.html
Also states on Imports 101 that they only do a 13.7, I know these are only rough figures and its from the internet so probably not dead right but eh...
Edited by Dani Boi
Yeh the GTR should be a low 13, I did a 13.765 with catback and a pod filter in the gts-t
Old stock R33 fuel pumps will start to fail,
they wont make fuel pressure,
your car will run lean,
and you will get more power
and u will run a mid 13
and ur engine will 'explodey poos
I dunno what engine is in ur datto at the moment, but the RB25 is probably going to be heavier?
You should be right for a low 13 second pass if you did the swap (stock engine/turbo with exhaust)
Edited by SKY RYAN
I'd be trying to get weights for your current eng/trans and also rb25det, trans, rad, fans, loom ect ect ect.
Just a guess, but the rb setup might weigh a tad or 10 more, giving you around the same curb weight or more than the r33.
Still it'd be a fun-different thing when finished.
I think the R33 are 1360kg.
From factory is was quoted 0-400 = 14.4.
No offence but how would a completely stock R33 would run 13.4?
actually,my nephew done the 13.3 when skyryan went down the drags a few weeks ago. he had the white r33 gtst with black mags. would have only had 200 rwhp - 220 rwhp. depends on suspension and 60" times. i had 290hp and could'nt crack a 13. skylines a 1490kg manual and 1520 auto.
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
