up for sale or swap is metal gear solid for PS3. awesome game but not really my kinda game.
played only twice for abount an hours in total or so. more then happy to swap for some other PS3 game.
ta
Ash
https://www.sau.com.au/forums/topic/261474-ps3-metal-gear-solid/
well seeing as EB and other game retailers are still selling for over $100 id be asking for $70 atleast or somewhere close to that.
if Harvey norman is selling for $54 then id say go for that.
if this sells they yay for me if it dosnt not fussed. will just keep it.
Hey mate, do you still have the game for sale? Would you take $20 for it?
sure man ill take $20....iv still got the plastic bag it came in id be more then happy to sell you that for $20 :P
sheng thanks mate but have payed farcry2 and not a fan of it.
also
BUMP :(
please no silly offers. i really dont cars if you can get it for less then what im asking. good for you if you can get it cheaper. like i said if it sells then yay for me. if it doesn't ill just keep it.
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
