Gents,
Sat 13th December is the day. $100 buys you 8 hours of drift fun at the Eastern Creek skidpan and figure 8 wet track. We need 40 people to make this fly and the numbers look fine from the interest post.
What will you need? a roadworthy car, long sleeves and pants non-flammable. No Helmet (to be confirmed!)
What will you get? 1min flat out drift on the two circuits every 20-min. An instructor will be on hand to give advice and help out with control.
Starts 9am and finishes at 5pm. Food and drinks will be available at the creek.
For those of you who are only interested in the 1/2 day please PM me and don鈥檛 use this post. I will work something out with Dave once I have the numbers.
No deposit is needed as wet weather only makes the day more fun, but please, only post up if you are 100% confirmed, if we don鈥檛 get the numbers then Dave will not run this even again and we will loose out in the long run.
Any questions let me know.
Thanks
https://www.sau.com.au/forums/topic/26149-drift-day-sat-13th-december-at-ec/
  • Replies 188
All,
Bad news Dave just went to book the pans only to find out it was booked by someone yesterday. I will now change the date to the Sat 13th Dec.
Blitz,
Can you please change the Date in the post.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
