  • Replies 105
hey everyone
thanks for all the emails and very amusing posts.
The shortlist to pick up Paul is:
R34 Z-Tune
Dom from Autostyle blue R34
and a Millenium Jade M-Spec NUR with 19-inch Volks on it
Vin will be going in a decked out Chrysler 300C and/or IS250
hey everyone
R34 Z-Tune
Why?
Universals taste in cars =
Edited by Black Widow
post-9339-1237421205_thumb.jpgwhat about this
hell yeah. I always knew you had taste greg. always been a snapper dresser!
c'mon andrew. as if vin wants to be seen in a 300C. they are just a poor mans caddy in the US. and still a cheapo car here. go the valiant. it's aussie and has some style! and will blow a 300C into the weeds.
hey everyone
R34 Z-Tune
Seriously though, same car??
edit: no it's not, this is a VspecII.... sorry
still think its homo that they can't have outside input.
They've given you the task of helping find these cars. You should have input as to what they use.
We know whats good...
No one else opinions matter :)
actually, enthusiasts aren't their target demographic, if it was they wouldnt get enough viewers. there taret demographic is " as many people as possible to buy tickets"
Cars had to be approved by Universal Australia and US. Publicist had to see it etc etc etc
you work i this industry you get used to it and just deal with it
hey everyone
R34 Z-Tune
not to sound like a party pooper here...
but seriously i dont see the point of all your hype.....
you asked everyone on their opinions....and for everyone to post you pictures of cars to suit...
but at the end of the day... none of the cars you mentioned that were picked ad nothing to do with ANYTHING, anyone has posted..?
so at the end of the day, everyone just wasted their time ?
anyhow
hope the movie is good
coz if not that would be 3 strikes in a row.....
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
