i think the motorman trick did work...
year 2000,i trashed a brand new car that has not seen 1000 km.(brand new sister's car)
taking it to the rev line every time in every gear.
and now the engine is still running perfectly and without any rebuilt since the day we bought it.
back here in my hometown, usually the mechanics ask us to run in with mineral oil for 500km's and then another change using mineral oil for another 2000 km's. only after that, returning back to use synthetic oil.
but we didnt opened the engine to check if the technique really worked.:)
  • Replies 45
Oh very interesting to hear, I've not heard of any engine builders around here using that method, especially with synthetic and not a mineral oil, I wasn't sure if it was a tried and true thing or one of those things that was done by one or two people and then argued on the forum as an opinion point!
Fair enough to go on what your builder says, most of my mates use EDGE and i've seen an RB30 with just under 500 000km unopened, with Castrol synthetics used nearly its entire life (mind you thats also a motor which wasn't thrashed). Thought that it may have had a detrimental effect when the car's being driven to its potential, due to breakdown of stabilising additives in the oil (due to it apparently being a hydrocrack derivative and not a 'true', synthetic.
But then over how many km's? (this poses an interesting question)
If your swaping every 5,000-8,000km's does it breakdown enough? Or is that only over longer service intervals and so on.
There are lots of variables if you wanna dig into it all IMO
Well from rereading a couple of pages in the oil thread, I'm guessing that visual signs such as fuel dilution and consumption of oil (you'd be hoping that would be minimal in a new motor though!), and if you're anal about it, a used oil analysis?
I don't know of anyone who changes their oil over 5000km either, I was of the understanding that only newer engines such as the LS family of motors could go for 10000 vs 5000km changes.
I think anyone asking for above average/high performance of a motor well above its factory specification should be changing oil frequently.
I change mine after every race meeting....cheap insurance. Actually its not that cheap $250 a change...but better than a costly rebuild.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
