Adelaide that is...........
Thats right, as some of you might already know, i have a full time job at Tailem Bend which is start in April, and yes ill be moving all the way up there to start my new life and career.
So i was thinking, before i go, i would like to catch up with as many people as i can.
I start on the 11th April (Easter Sat)
So how about (if anyone is interested lol) meeting up at the Holden Hill Pool Hall on Thursday the 9th April before i go?
Let me know :D
https://www.sau.com.au/forums/topic/261542-well-im-leaving/
  • Replies 102
Holden hill,, geez might have to pack a cut lunch and extra water for that drive ..lol .. but will try to tentative say yes Cara, is it safe for lines to be parked there ?
and we can plan a Road trip to see ya..lol right Ben ??/?
https://www.sau.com.au/forums/topic/261542-well-im-leaving/#findComment-4483241
most of the cops use that back street to get back to the station though too
I just park from the main road into Hogs Breath, have a quick meal, then play pool. Easy.
Or, you could just drive in and not be afraid of cops.
https://www.sau.com.au/forums/topic/261542-well-im-leaving/#findComment-4483503
lol Cara, when I saw this thread I thought that you might be heading overseas or something then I realized you'll only be an hour away.......takes me just as long to get to Munno Para :D
I'm sure we'll see you reasonably regularly still....all the best with your new job
https://www.sau.com.au/forums/topic/261542-well-im-leaving/#findComment-4483525
Great idea there Cara ... how'd you ever come up with it. :D
I'd be in for Hoggies and pool. The jukebox thingy there has loads of Linkin Park too. Woohoo!
Edited by RubyRS4
https://www.sau.com.au/forums/topic/261542-well-im-leaving/#findComment-4483546
Guest
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
