Firstly, are there any ecu's on the market with an in-built fuel pump controller? Something that will regulate the voltage at differeing rpm, so the pump isnt running full noise 24/7 and heating up the fuel.
Main concern is big pumps in street driven cars.
I know aeromotive do a unit, but its only a 2-step i.e only regulates voltage based on 2 rpm inputs, well thats my understanding of how it works. Is there anything out there that gradually increases/decreases voltage in relation to rpm?
If you run a big pump/s, how do u combat this?
https://www.sau.com.au/forums/topic/261568-fuel-pump-controllers/
The ViPec/ LINK G4 just use two auxilary outputs. They are configured as fuel pump for one, to switch on, and the other is configured as Fuel Pump Speed. This is activated when a set revs is reached (and or %Inj Duty cycle ).
The switching obivously needs a relay with a resistor inline with the pump to be able to switch it in and out as needed. As in most factory efi setups for the last 20+ years.
Gary
You could use an aux output set to pwm to control the pump that way, but you would still need an external driver (ie ignitor module ) to drive the heavy current loads a pump would use.
Show me any ECU that can control pump speed out of the box directly.
And whats so hard about a relay and resistor ???
Gary
Gary
yeh thats the way i meant, use a pwm output to control the pump via a relay and resistor. in the haltech its got a 32x32 map for it aswell. need to discuss it with my tuner though
If you use PWM you won't be needing a relay and resistor, just an single channel "ignitor" would be necessary to controll the large currents possible.
The link can quite happily do this and has a 3d map based pwm outputs as well.... and you can specify what ever you want to be the axis's of said 3d map .... boost*rpm or %inj duty*rpm ect .....
Any ecu will need an external ignitor channel to control the pump.
So...... no need to ditch the Link/Vi-pec
Seriously, its really an impressive bit of gear.
Gary
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
