  • Replies 69
Sorry guys, so many questions..........
GT1 first , http://www.hioctaneracing.com.au/
We use them (as Performance Metalcraft) for fabrication when our team fabricator is too busy or away. They do top work.
Rev210, they have Tomei camshafts in stock. Sorry my cattledog is at work.
Inasnt, yep the Tomei Poncams are designed to work with VVT. Don't bother with an adjustable exhaust pulley they are pretty much spot on standard, spend the money on something else.
Hope I answered everbody
Rev - I think this is the mildest:
Tomei Cams 256 duration and 8.5mm lift compared to standard 240and 7.8mm lift
That's what I am putting in my car during re-build
YEs, I understand they work with the std hydro lifters - I'm not changing mine anyways - Unless the head people do that without me knowing about it.
Price - Well, I think I'm paying a bit more than normal - but I'm also getting a package deal and make up for it on other things - So you should be able to get better then $1200-1300 - Cheaper if you import yourself (But not quicker) you pay a premium for off the shelf stock on Oz......
Hi INASNT, if you mean "headwork" as in clearancing to fit the camshafts (not porting) then duration is basically irrelevant, lift is the issue. When we get the lift over 9 mm, we die grind the head to clear the lobes. Pretty simple, you can do it in the car as long as you clean up properly afterwards.
So to answer your question we have run 292 @ 9 mm without "headwork". We also have run 264 @ 10.5 mm and done headwork.
To answer the second question, based on my personal experience;
240 is standard GTST
248 is standard GTR
256 is a good mild street upgrade, go for 9 mm lift
264 is a good combo (street, track, circuit) go for 10 mm lift
272 is a good for circuit work at 10.5 mm lift
Anything more than that requires a big turbo/turbos to use it, to get the best a close ratio gearset or an auto would be my suggestion.
There are plenty of people running around with more than the above, but they don't seem to keep the car very long. They get there jollies from the doing (or the bragging) rather than the driving.
Hope that helps
  • 5 months later...
Hey guys
does anyone know how a HKS step 1 (I think they're 256 whoops I meant 264) exhaust camshafts would go with the standard inlet Camshaft?
being step1 I heard they're ok for on the street, but would they work with standard inlet cams?
Also any ideas where I could get the stock exhaust Cams?
Im having no luck here in WA
I'm confused, I have seen 256, 260 and 264 described as "Step 1". Plus I have 264 described as "Step 2". So I just call them 256, 260 or 264, "Step" is a useless term.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
