I'm in the same boat, you don't mind paying to get the little things done as long as it keeps the warranty protection valid though.
Atleast if something does go bang you can use the warranty to repair it.
My warranty (don't know about Andy's) requires the work to be carried out by a workshop and the invoices have to be sent through to the warranty company.
i.e. if they do not receive an invoice for a service or it isn't serviced in the correct intervals your warranty is non-void and leaves you up the creek :)
yeah i have warranty too with my car, im guessing its not worth the paper its written on right at the point where i need to claim on it :sick:
anyway, my mate is happy to stamp my log book to say he did it when it was actually done by me. i love getting my hands dirty and actually doing stuff to my car. plus the money you save in the long run too. and iamhe77, is spot on. some places will charge you $200+ for a service and use cheap mineral oil and a cooper oil filter that probably totals $35. i do it myself, spend $45-55 on oil and a nissan oil filter and i KNOW its been done properly.
but yeah ok point taken with the warranties you guys have.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
