There is usually an occurrence of minor boost creep with colder temperature. Ie 14psi at 30 degrees and 16psi at 10 degrees, I haven't see it going backwards. Perhaps tune or ignition related?
Look at the torque difference at 3k between your SS2 and the latest one.
You'd expect the Neo engine to produce a little more response anyway...I'd think? That latest run is an S2 R33.
That car had a bell mouth dump with a hi-flow cat. On the standard manifold, I was impressed.
The car equipped with the older version SS2 had a ebay exhaust manifold on it during the time. So that difference contributes to the larger exhaust manifold. The differences between those two turbos are minor, how ever the new SS2 has better ability in boost control for internally gated setups.
Definitely a good result, its a good bolton turbo.
I'm pretty sure the new SS1PU will follow the same league, that will be amazing.
Oh ok, lol fail.
There are 2 areas I am dubious of. One being a hose that is a PITA to get to which had cracked previously and I cut down. The other being the EGR port at the back of the IM. I made my own little block off plate for it but I have since sealed the actual EGR valve which I can put back on with an OEM gasket. That will likely be better than a silly piece of alloy.
I'll see if these are an issue :)
I had some issues with cuts and Nistune on the Stagea with load cut. I am not sure how why it can hit the set value while driving but not on the dyno but I lifted the values to the max as any cuts while driving on the road are a little risky.
Do you have the Nistune software to check where Yavuz set the load cut?
That I do not! And the car is unreg so I can't easily take it back to him to have a gander :(
Jez is also miles away so am stuck with very little help. I may need to lash out on some software.
Awesome result Scott. A 13 flat Is nothing to sneeze at on street tires.:) can't wait to see the times you pull when on a full tune. What are you hoping for?
Josh
Cheers!
Re ECU LOL Nah, can't.
I have spent just shy of $3,000 on the Nistune and tuning to get to this point.... Admittedly only half of which relates to the current tune and motor (last setup was a failure), but it is still a mega investment I would feel stupid to give up on.. Resale on the nistune would be next to nothing. I just need to go bark at the tuner about the couple of issues I have with the tune and get it fixed. I believe they relate to the weather on the day of the actual tune, limits were just set too low and a flat spot pre 3k rpm probably couldn't be felt on the dyno.
Am gonna think about investing a little more into better boost control and will simply get the tune tidied up.
Am expecting the final result to fall close to the 260rwkw mark and I think I will snatch a low 12 :) That will be enough for a car that doesn't cause a scene when it comes out to play. Simple car, simply good results.
Its best letting the tuner keep and drive the car for few days which allows him time to explore any minor imperfections. If he believes the ECU is fine and the car is welling behaved well within its command then there isn't much of a point replacing it.
If not invest into an adaptronic plugin ecu. They worth that 3G lose.
Got my 20psi actuator today off stao
Awesome service just ordered yesterday
Looks heavy duty the rod is a lot thicker where the std one is a 10mm locking nut this looks to be a 12 or 13mm
Can't wait to fit it and try to get it to hold 24psi flat and then ill take it to the wsid fingers crossed 11s
It drives so much better than before touch the throttle on 18psi powers there instantly if your cruising a 3krpm it's scary fast if there's no wheel spin where before I had nothing till 4krpm
Sounds awesome man. Glad you like it.
is yours an SS1PU like mine or a G2? Whats the actual spec, stao please confirm?
also Urs is VCT or S13 spec motor?
Here's a dyno sheet of a s14 with the same turbo but no fnt and not e85 it's not perfect comparison but same dyno
the fnt has shifted the powerband towards the left
Mine makes 20psi by 3600rpm his makes it by 4400rpm
S14 make 90kw a 4000rpm mine is making just over 200kw
http://www.nissansilvia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=246012
Edited by hy_rpm
The FNT makes a big difference for sure.
Mine saw 20psi at 4000, but I'm curious to see what it will do when I go back on a cooler day. I've got the S14 motor but its not running VCT. Just S13 spec Poncams and gears. Tuner didn't touch the gears though :(
Admittedly, the powerband is awesome at the moment... I don't need it any stronger and the torque I get at 4k is nonsense. Once I sort my tune I will have to organise a drag night with you. Not gonna go back till I fix this boost/load cut issue. Got to decide what to do about boost control first but.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
