I'm planning to move to these injectors:
http://www.injectorshop.com.au/product/siemens-ev14-875cc-12-ohm/
I've contacted the shop - however still waiting on a response.
I hope those Siemen's are better than the ones I used to run... I would hate for you to have issues with another set of injectors to save $10ea Johnny. ;)
I just picked up a set of stainless 1400's for my evo 7 today, we are tuning the reverse rotation SS2 Hypergear evo highflow on the weekend, stock exhaust, intake and cooler for the engine run in. Should be interesting. :P
If you are using this fuel pump:
$(KGrHqVHJBcFBUUDMsuFBSbLZJsTnQ~~60_12.J
You must run two earth. You can just Tee it from the factory wiring and connect it straight to - terminal of your battery. It will then work.
Interesting that you should say that. I have mine required through a 60 Amp relay and suitable wiring, and twice it has killed the earth.
Both times the car was running perfect, left it for an hour or two and it just wouldn't prime. Both times the earth went open circuit. All other wires were fine but the earth was dead, and there didn't appear to be any damage to the wire. Certainly didn't look like it had had too much current through it.
Why wouldn't you run a dedicated earth back to the battery though, while you run the positive?
Would be intresting to see your results on the evo 7
Mine made 285awkw on 25psi
Turbo is back at stao now for a turbine wheel upgrade to a td06h4
Hoping to gain better response and crack 300kw
The stock exhaust will be pushed hard, 2.3 Manley stroker, HKS step 2 cams with adj wheels, the rest is as factory. It's the most un-defectable car it will ever be, for a few weeks at least. ;)
If I can squeeze 250kw out of it I will be impressed. That will do me while the engine is run in.
Keen to see how those injectors go Scotty because those are the ones I'll be picking up off you when I get back.
I have installed them on quite a few cars lately, they idle fine as you would expect from a modern injector, no issues at all with them.
Looks like Im the only one left with five0 injectors that havent died yet lol I ordered 1 Spare now incase they do ever die while im at the track. So even on e85 you still having idle problems? Thats strange
Nah, mine are still doing 295kw and 10L/100km.
HIGH FFIIIIIIVVEE!!
T
HIGH FFIIIIIIVVEE!!
They perform differently on a SR - I fitted and tuned a set of 1000cc and my mate is getting 400km per tank on E85. Only about 120km less per tank than 98RON
T They perform differently on a SR - I fitted and tuned a set of 1000cc and my mate is getting 400km per tank on E85. Only about 120km less per tank than 98RON
Mines on are RB, most the failures and issues have been with people using the 1200's maybe there the issue cause im using 1000s.
They probably used a bigger drill bit and it's causing all the issues. Also the spray pattern looks like ass, I'm pretty sad I jumped the gun and bought these water pistols.
When you make a mistake there is only three things you should ever do about it
Admit it
Learn from it
Don't repeat it
Admit it
Learn from it
Don't repeat it
Expensive lesson :(
I have admit they suck and taken my learnings and documented it on nissansilvia.com
Perhaps they are damaging the coil with the drill bit? Seems very unusual they go open circuit... Just keep a few spares in the glovebox. lol
Probably their drill press operator went a little too deep LOL
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
