Johnilicte: I'm doing a little bit of Noob tuning at moment following course from HPA. Would you be able to share some experiences in tuning Nissan VTC system in areas of ignition, fuel and dis/engagement? I'm using adaptronic ecu. Thanks.
of course, e-mail me all your questions and I shall answer ..
Long story short with VTC enabled you produce more torque due to higher cylinder pressure thus the motor can only take less timing, as soon as it disengages torque will drop off - reducing cylinder pressure allowing you to ramp up timing again. From my limited tuning experience, motors with a shorter stroke will prefer a mild ignition ramp after peak torque, where as a longer stroke motor i.e. SR OR 4G likes loads of timing hammered into it after peak torque.
Best way to determine where to disengage VTC... setup a mild timing map with VTC on a few thousand RPM past peak torque ~6500rpm (of course monitoring knock) do a dyno run, then set the VTC point around 4500rpm do another run..
Overlay the two torque curves and you will see your optimum VTC disengagement point.
Of course after you do that, you can start ramping more timing after VTC disengagement and tune for power up top.
That's a quick run down of it.
Just a note, I've never worked with variable cam timing and variable lift.. RBs and SRs use a fixed on and off point which makes tuning easy for an amateur like me.
In terms of injection, VE is closely related to torque.. more torque higher VE so it's natural you see your VE decline as your torque drops off.. this is the beauty of VE tuning.. makes tuning easier
Thought i would post up my results of Stao's fantastic handywork. My car has sat in my garage for 1.5 years, and finally got round to fixing it.
Unopened RB25
Pretty much the usual stuff.
740cc injectors
PFC
Greddy rad and cooler.
Scotty Intake
Just a typical hiflow which i bought 15 months ago. I was told it would see 230kw on 98 and roughly 260 on e85.
Anyway today i picked my car up and got this:post-75784-0-29419900-1405668770_thumb.jpg
All on BP98. Might be interesting if i put it on the juice.
Highest run was 265.
Unopened RB25
740cc injectors
PFC
Scotty Intake
Anyway today i picked my car up and got this:attachicon.gifIMG_0171.JPG
is it an R33 highflow? the new ones can make around 270 rwkw around 20-22psi on 98 so your result is very good for around the 17psi mark. Personally I wouldn't push it to 20psi on a stock motor on 98 but it's possible.
The old highflows maxed out around 230 I think.
on e85 the new highflow makes around 320rwkw around 22psi
Been running 20psi on a hypergear turbo as a daily for 2 years now :)
Boost doesn't kill engines it's detonation that kills engines.
  • Like 1
Dont mean to interupt but what do you mean new hi flows?
@Johnilicite: Thanks for the info. Using the adaptronic ECU in the VVT tab. This is for the Kia sportage. would you know what those sittings are corresponding for? Thanks.
And Grimsy. Thanks for submitting the dyno result. This is using the current profile, the very distinct difference between the two, is the current model has no issues holding boost and much happier taking on timing. Great work.
My brother got his s13 road tuned today with atr28ss2 and s15 VCt motor only on 20psi due to running pump 98
Goes good but definately doesn't feel as fast as my 180sx but power feels very linear and comes on instantly
Not like mine as it hit 3500-4000rpm there's a big surge in power and throws you back or tyres fry
We will soon see the difference as were going to the drags soon
Thanks for the feed back.
Everyone getting in on those HPA courses atm!
cheers
darren
I do highly recommend people go on the HPA site and at least acknowledge the content in EFI fundamentals and road tuning before even think of modifying any cars.
It would contain a good entry level information for a brief understanding of what the tuner does, what a good tune is, and how power and torque is generated in relation with supporting mods installed.
#@hypergear - with constant variable timing this is where it gets really fun/confusing as the cam timing varies over RPM & LOAD, i.e. MAP
Ignoring the duty cycle settings (determines how much duty is required to shift the cam actuator) & and the controller gains (closed loop calculations P = proportion gain at present correction, I = Integral gain past correction, D = derivative gain future correction)
VVT1 = Intake Cam
VVT2 = Exhaust Cam
VVT1 = uses Fuel 2 table to set the angle, which is depending on RPM & MAP - this makes it 3 dimensional, that being (RPM, MAP and angle of advance/retard).. so as MAP increases and/or RPM increases the timing changes. If you click Target Angles it will take you directly to Fuel 2 table.. please note the values showing in there are not fuel correction values.
VVT2 = uses just a standard RPM table, there's only 2 dimensions in there.. that being the RPM and the angle of advance/retard of the cam
Unfortunately I've never tuned cars with varying cam timing so I can't input too much here.. I've always worked with Nissan's dinosaur on/off timing (which makes tuning much easier too) :)
But I can imagine as RPM increases you would want the advance on the intake to decay i.e. retard, however at the same time you want to advance the exhaust cam as RPM increases to promote more air being "pumped".
http://www.learntotune.com/
for anyone interested..
cheers
darren
Yep, did that! :D Going for a 1 on 1 course at Unigroup Engineering once i register my 300ZX :D
Anyone used Siemens Deka V injectors? they come in "short" length, i.e. 48mm end to end OR 35mm O-ring to O-ring?
They seem to be pretty good based on these tests:
http://racetronix.com/product/Injectors/FI114700_Brochure.pdf
I've been trying to redo my injector needs by finding a cheaper alternative (yes I'm being cheap, but I can't envisage spending $1.2k+ on stuff when the motor cost the same price)
Posting some updates:
Been dummying some direct bolt for Holden VL Turbos. This particular one is made based on our ATR43G3 turbocharger. Factory 2.5 inches cast dump is not replaced with a full 3 inches dump including a much larger 38mm internal gate. Expected to support 260~280rwkws on a RB30ET with supporting mods on P98 fuel. Bigger profiled turbochargers can also be be built based on the same turbine housing configuration. That includes our ATR43SS2 (500HP), SS3(530HP), SS4(550HP) and G4(600HP) models.
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
