and a K&N panel filter on the street.
Kill it with fire.
Oiled filters should not be anywhere near an AFM, and I have had better results with Blitz style cotton elements, they flow 500 odd kw.
  • Like 1
Kill it with fire.
Where would one purchase said blitz style cotton element?
  • Like 1
Best bet would be Ebay, US is very cheap if you can find a decent postage rate. Greddy do a good one, even a Drift one would work well I guess.
  • Like 1
Thanks mate, I'll be changing mine soon and I think the ones I've been using have had oil on them because I'm cleaning my AFM every 2000ks because of misfire (and yes it's 110% the AFM that's the culprit) either that or it's rooted.
There is a LOT more surface area on an OEM style paper filter than any aftermarket cotton or oiled style panel I have seen. I'm not surprised they flow well.
That's what I'm sayin, for the $10-$15 for a paper filter why would 1 bother with a $100+ fancy after market brand name filter if the cheapo paper one will flow the same but have 0 issues with oiling and filtration
Hardly $100, cotton panels are $20 in the states, we just get raped with retail prices. Autobarn tried to sell me a BMC panel for the Evo for $130 the other day.
Bucker, 20 uckers for the cotton filter, how much for freight from the states cause those farkers see Aus and slam up the postage
Yeah $150 odd I paid for the K & N shitter then had to get the compressor out and blow off the excess oil, THEN Pauly tells me he runs the paper jobby :(
I got angry at my shitty homo Five O Motorsport Injectors.. so I just ordered a top feed kit with Siemens DEKA IV 875cc injectors... broke now.
been getting around 180km to 200km per tank of E85 - just had enough of that bullshit economy
are you putting a link to this thread in the for sale thread? or you just gonna shit on someone else? :domokun:
I've put all the details in the for sale thread - have a read, I'm not a prick.
wasnt saying that.
the shit on someone else part meant that the guy who sold them to you f**ked you over, hopefully you would tell buyers what to expect.
no offense intended, but zero f**ks given if it was taken. :yes:
hope you can offload em man.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
