Funny my new gtr 33 just did 270rwkws with front drive shaft taken out. Fully stock with 3inches turbo bacm exhust. Not sure if the last version of gtr33 had some tricks into its sleeves.
Nah that's about right
I seen a r32 gtr with just catback dynoed at Unigroup back awhile ago made 250rwkw on rwd dyno std computer
And I was struggling to make 230rwkw on my sr20 cams turbo injector afm tune
6cylinders especially gtr make power very easy
Sounds off, doubt its a stock ECU tbh. Seem more than a few of them struggle to hit 260 tuned on standard turbos.
12% I think is the agreed difference between awkw and rwkw for the GTRs.
270/1.12 = 241 awkw which sounds about right if it's missing the boost restrictor?
Most R33/4 owners wouldn't bother on a RWD dyno due to having to remove the front shaft. Whereas on the R32 its as simple as pulling a fuse, or flicking a switch if you've got it hooked up that way
Edited by Blackkers
But a highest reading out of a stock GTR on this dyno was 207rwkws on factory tune. My boost curve appears to be laggier also, but not as laggy as the N-1. Pretty much spot on with -9s. But every thing is stock. Its the only Navy Blue GTR Trent's ever seen either. I always gets stooged with cars that makes stupid power.
This is power vs a normal GTR33 on stock ecu:
Boost vs Stock R33 GTR:
And AFR
Timing, ignition, fuel, AFR, Pretty much every thing is spot on. Std GTR 33 tuned with PFC was getting 245rwkws on 14psi. While this is fully standard with a cat back exhaust. It felt very different to drive compare to other GTR 33s I've looked recently, I was expecting around 180rwkws not 270rwkws.
So well this is my base line for this GTR.
+1 for the 'not actually stock turbos'
Given -7's and -9's and -5's look identical from the outside to stock turbos, I'm going to say they aren't
...they are also what Hypergear are up against in terms of 'bolt on 100% legal high flow-looking' turbo options, curious to see if Stao can get turbos to respond that well and make 375rwkw on E85 and look entirely standard which is what a -9 will do
Or more than 500+rwkw which is what gtx2863 fronts will do in standard housings :P
The previous owner is a farmer, he knew nothing about cars, it was sitting in his garage for a long time. He said he only driven it to his mechanic for a oil change every 4 month, and clocked 4000KMs for the past 5 years. He's wife made him to sale it.
I'm more interested in the Rb26dett power and response thread. I will be starting with a single setup once the manifold is ready. Too much hassle getting E85 when needed, This car will be running on P98 fuel.
Update compared to my previous result with the following changes:
1. Rebuilt actuator arm by Stao with more preload (around 3mm) - this is a Z shaped one as opposed to the original straight rod
2. Rebuilt & tucked in exhaust system:
  • JJR bellmouth - bottom half has been recut/customised to run as close to the floor as possible
  • Venom 5" cat - bought without flanges, which were welded on at the exhaust shop for best alignment
  • HKS Super Drager cat back (R33 coupe model) - mid muffler replaced and moved further back for better clearance, most of the piping redone in 3"...
3. Retune at Chasers
Result: 275rwkw @ ~20psi, BP 98 Octane (red line)
Without airbox lid, snorkel and filter: 285rwkw (top blue line)
It also has better response than before so the actuator and exhaust mods have helped.
The intake is restricting it a bit and I reckon that the Trust turnflow might be at its limits, too.
Thanks heaps Stao and others for your help on this!!
Great drifting :thumbsup:
Result sent in, This is our ATR45 turbo on an Ford XR6 BA. Final result of 400rwkws on P98 fuel internally gated bolton at 19psi of boost.
  • Like 1
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
