A bit OT but how are you graphing all your logs like that johnny? Neat and easy to digest :)
it's just excel :)
I create pivot tables with filters then create graphs from it
Alrighty, part where everyone gets excited..
Details:
  • Hypergear SS2
  • 45mm Turbosmart External Gate off Housing (thanks scotty_mn35)
  • E85
  • 1.6bar boost, made more power on 1.5bar
  • IAT shot up to 50 degrees, subsequently lost 3 degrees of timing (I take 1 degree off every 5 degrees above 35)
  • Stock motor
  • Stock manifold, stock plenum
Timing Map:
Dyno Reading at Power Tune:
Virtual Dyno Reading (Using Log File on the same run at Power Tune):
  • Like 2
awesome result. just out of curiosity did you try to add timing and lower boost in the top end while on the dyno to try pull IAT's down a bit? if so what happened?
Edited by Blackkers
Car was just at a dyno day at Powertune so I wasn't controlling the runs..
I did tell Chea to run the car with different boost settings, but at 1.6bar it bled down to 1.5bar. Ended up doing 1x run at 1.5 bar and 2x runs at 1.6bar...
I'll upgrade the FMIC and then hire out a dyno and pump more timing through the motor. Adam at Powertune did say my manifold was glowing red by the 2nd run. Signs of high EGTs and/or flow restrictions.. probably won't get round to doing any of what I said till February.. barely have time to do anything with the car these days lol
Johnny,
Your approach is probably wrong. 50°C IAT is nothing. Certainly not enough to be pulling lots of timing out. You really need to listen for knock properly and decide where/when it becomes apparent and make the tune safely away from there in the usual manner that people have always done. When you're pulling timing at those relatively mild IATs, you're causing high(er) EGT.
You're using E85 which will smother the effect of hot air a lot better than 98 will. Gives you so much extra protection that you're probably massively overdoing the engine protection routine by backing off the timing the way you are. If you wanted to be fussy about it you'd be better off pulling boost off it as the IAT goes up.
Problem is with E85 you can't really hear knock.... I do monitor for knock but regardless of timing or boost levels put through the motor the knock readings are pretty similar (mind you it's just a basic knock monitor I'm using with the Adaptronic).
I was always under the impression IATs past 50 degrees Celsius is bad, thus I pull back 3 degrees at that point.
Most of the runs have been with Virtual Dyno used to estimate torque/power gain. I did some logging when I was at Wakefield too with the laptop under the front seat strapped down.
I can't pull boost as IAT increase as the ECU doesn't have that feature and also I use a dedicated EBC which allows for quick changes of settings.
In saying that the tune isn't complete, I haven't hired a dyno to finalise and push the tune further as I was still ironing out some bugs.. hopefully will do that after the new year once the shop I hire the dyno opens back up for business again.
Ok, so I did some quick reading of a few engineering papers and this came up - although it's for a direct injected motor..
Looks like I may be a little too cautious with the whole IAT vs. Timing.
Just a note 3 day turnaround Maybe??? ,Then 7days to post back WTF??? ,if you go this route make sure you ask for an express post return , don't assume they will post it express unless you ask !! And yes I did call and ask about the turna round time ,etc etc , just sayin so others don't get caught with with a car siting in a work shop
Express option is available to chice from on our site, default is parcel post with insurance. How ever during xmas break delivery time can be unpredictable.
It wasnt Christmas it was last week of November ,I asked if I could check out on line and they said do it COD ,I am just giving a heads up so others don't get caught out .
I have had similar issues with COD it can take Aust post ages. One of my deliveries took a week, sent from the other side of Melbourne. lol.
Not Hypergear's fault. Pay for a courier if you want express delivery.
Yeah COD is often awkward like that. I had waited a while before checking with the post office that said they'd had it for a week... I was never notified. Not hypergear's fault though and the turbo was worth the wait!
Hope every one had a lovely new year. :turned:
I've spent a lot of time but haven't had alot of luck with the GTR yet, I've fitted over 20 different combination of turbochargers to it and yet can not get it to reach 20psi any quicker then 4300RPM. Due to the lack of VCT, the head doesn't like boost down low either, result in a violent surge working with smaller turbochargers, Then the only way out is by creating more lag.
How ever I'm narrowing down to a few sets of wheel and housing combinations for the most responsive 400awkws as possible. Will be doing further evaluations with it using adjustable cam gears down the track.
Result sent in by another member that is currently using our 21U high flow running E85 fuel making a super responsive 311rwkws on 20psi internally gated. That is on a R33 Rb25det stock engine.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
