Picked up this bad boy today after reading all 530 pages of this thread
10523565_856078507785625_194948415913983
Going onto an RB25det NEO in my R31 Ti
- Sard 650cc injectors (pretty rubbish)
- 2.5" cooler piping from turbo to t/b, 510x250x65 intercooler tube and fin (may be a restriction)
- 3" dump pipe, highflow 4" bodied metal cat, 3" exhaust with 2 straight through mufflers
- Aeromotive 340 stealth pump
- Nistune ER34 board
- Hypergear ATR43SS2 with op6 rear end to suit
- IWG welded up
- Turbosmart 40mm comp gate welded onto housing
- Screamer slash cut at passanger foot well
- 3" metal intake
- Z32 AFM
- Stock R31 airbox with highflow 'drift' filter and rear of lid chopped out (loses ALOT of power with unmodified lid, tbh most likely going to fabricate a custom airbox with panel filter.)
Hoping for 300 on P98 but will be more than satisfied with 280ish.
This should be easily possible, I'm back on the dyno today after changing the intercooler to see if i can hit 300kw mark on a rolling road, currently 284kw. Will update this evening.
Hey ben, keen to see how the nistune flex fuel for the neo goes been trying to find out about it. Let us know how you go mate. Other wise great setup (i wouldnt mind doing an op6 rear on my ss2 as well
When back on the dyno, try a run with external gate screamer un-pluged from the dump pipe or let it externally gated. It will pickup more power on less boost that way.
Will you fit, balance and machine a comp housing to fit a gtx billet 71mm in a hks gt2535 tao? Or fit, balance machine a comp housing and fit a billet wheel of your own you u think would work with gt28 rear? The standard 2535 cast gt wheel is 69mm 56 trim and thecomp housing is .50 non surge slotted housing.
can be done. I can supply a SS-2 comp wheel , that is in 74mm. fitted, balanced with comp housing machined for $450. Alternatively:
Balancing $100, Comp housing machining is $150.
What sort of power should that be capable of with the gt28 rear wheel ans ss-2 billet on e85 wih the .64 hks rear. Id like to whack a exrternal gate off the housing to get rid of excess heat or wouls it be wirth porting the internal gate out as far as it can go? Thanks staoyour customer service is2nd to none.
on rb25 all supporting mods and 256 vtc cams. Yet to decide on a ecu yet. Want flex fuel and launch control. Lol
Edited by Joshbigt62r
GT28 rear is no good for RB25det engine, I don't recommend of fitting a much efficient compressor as it chocks the engine even worse. Since it is still working, sale it and get our standard 21U high flowed unit (we can supply donor turbo if you don't have one). it will make more power with same or better response.
10295196_10152932108354924_1802155133729
this makes me think you spent waaaay too much on a 31. Either way it's going to be a monster
more than you can imagine for a 31. lol.
had the car for 5 years though, and was my first car so doesn't really bother me.
*i do everything myself so dont think about fab or labour costs*
Edited by AUSBen31T
didn't try the wastegate vent to atmosphere...but here are the results anyway...which to be honest i'm pretty stoked with.
290rwkw @ 1.3bar on P98.
this is on a rolling road dyno. When i can i'd like to see what it does on a hub dyno.
only problem of the day was the Greedy type RS Bov started to leak quite badly.
Pulling the highflow off right now after i saw that lol , i love how consistant yours sits at 20psi with the same gate as me, hopefully i don't have issues with the op6 rear housing for control.
I have a pair of -7s, one of them has slight damage to the comp wheel, the edges of the fins are rounded off, do you have a billet comp wheel that can replace these of the same size, I also want to have the factory .48 rear housings I have fitted to them
I am lookng to track only my 32 next year and want to replace the factory turbos while only losing as little response as possible while being able to run 19-22psi on the track without them blowing up
Alternatively I have complete stockers if you have CHRAs that can be fitted to the factory housings
I can vouch for the 21U highflow. Guilt toy was impressed with it too. 273 rwkw on 17psi with P98 and full boost at 3300rpm in 4th
We can high flow them to -5 or -9 depending on the HP chasing for.
With the damaged -7s I need to have a look at the turbo, the smallest billet wheel that I currently make is in 60mm that made 250rwkws on P98 on my SR20det.
Hey tao, how much to health check and possibly rebuild a mid 2013 SS2?
Blows a bit of white smoke on decel so not sure if it's turbo or valve stem seals. Turbo seals are easier to replace so will try that first :)
Free of charge.
Before taking it off. have a feel of its shaft play. There should be about 1mm side to side and nothing in and out. If that is the case, check your engine breathers. if you do have a catch can, remove it and let breathers breath into atmosphere and see if the problem goes away.
Appears that you looking for results for this type of application. and I actually found one from few years back. This is during the evaluation and development of ATR43SS1PU. Dyno result shown 2535's 53mm turbine in .64 rear working with a older version of SS'2 billet compressor wheel, heat soaks with timing deducted avoiding detonation:
for your power level externally gated, you can use our ATR43SS-2 that boltup to most of your factory bits, or the SAT version of ATR45 (result appeared on Rb26) can be made as a bolton for RB25det or a SL2.05 in 10cm turbine.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
