Only if it's blocked.... Ive made 290kw with a blitz return flow.... I'd eliminate the boost tee first. My mods are similar to yours.
Edited by Badgaz
what size is the rear housing on the turbo? also that graph isn't that helpful...do they have one that shows rpm as well as afr?
Edited by Badgaz
Big ups for Tao especially for the Highflow and SS2 offerings. I've been running a 21U highflow now for almost 5 years.
The latest one has the ATR compressor housing with the latest wastegate and exhaust wheel design.
On a standard engine, standard exhaust manifold, standard intake manifold, greddy cooler & havoc hard intake pipe with a Z32 & 850cc injectors it makes over 300kw on pump E85 with 18PSI peak bleeding to 16PSI at the top.
But it's not the peak power figure that I love, it's the response and delivery of torque.
  • Like 3
or just a basic MAC valve and let your ECU control it (if it has the capabilities), there's no way a bleed valve can surpass an EBC which runs in close loop oscillating to control the boost.
  • Like 1
I don't think the advantages of a EBC are drastic enough to correct a ~50rwkw deficit.
My TurboTech made 270rwkw no worries at 19psi and held it perfectly on an OP6 highflow.
  • Like 1
I do agree, but if he is looking to replace the boost tee as a possible source of power loss then I think he should get an EBC whilst he is at it. There are many advantages/features in running one.
Edited by owen1r
Hey tao how much is your Hypergear ls20.5g? Is it best run with a external gate and good high mount manifold? Or is there a bolt on version you make with stock rb25 6 bolt rearr.? Id probably prefer a vband rear. Make the price with the lines and whatever else ill need? Will it make 330-350kw at the wheels on e86/wmi and 270 ish kw on plain 98? Also how good does the adaptronic go compared to the likes of Vi-Pec/Link/Haltech ect in plug/play versions ofc. What can you do the Adaptronic for $$$'s wise with the sensors ill need and everything to just plug it in and set it up to go haha
