any tips on adjusting preload on actuator?
I usually run around 5mm of preload, or slightly over half the width of the hole. Depending on the spring it will take a bit of effort to pull the actuator back over the wastegate pin. The more preload the less the wastegate will travel, so you may need to dial it back a little if the boost is rising higher up in the revs. (unless that's the boost curve you are going for.)
Don't lose the circlip. ;)
  • Like 2
found this video from Tao, great music choice :thumbsup:
will run approx 3-4mm as advised by Tao. if i adjust actuator, will it affect the tune ?
my turbo 21u hiflow is getting fullboost by 4500~ which is very laggy.
me and toshi tested with no airbox cover on and it help response dramatically but no where near the 35-3700rpm it should be getting fullboost by.
current mods
480cc
21U hiflow
3" turboback jasma apexi superdunk
2,5" cooler
high pressure hypergear actuator @ 19-20psi
unopened rb25det s2 r33
Toshi suggested to run pod with EBC and it will help around 4000rpm but i want the 3500-3700 response that the 21U is supposed to make lol
didnt get change to run on dyno or complete 3rd and 4th gear runs as clutch slipped over 5000
If car is sitting on 1st gear then do expect 20psi over 5000RPM, I would advise of a clutch change and have the car fully tuned before trouble shooting take places, then preload the actuator through actuator bracket if needs to be.
Dude are you elvis? you bought my old turbo?
I had the 20 psi actuator installed with about 1-2mm negative preload on the actuator to bring boost down to about 17psi when i switched to 98. That killed response
Fit the black kinugawa actuator I gave you with about 5mm preload and you will get full boost around 3400rpm in 4th with max boost around 14-15 psi
  • Like 1
yeap
i don't get 17psi, i hit 19-20 lol
perhaps my mechanic may of moved actuator slightly as he installed a circlip to replace your wire you used.
Will do, Cheers Tim!
tao, can you confirm? shouldn't the high pressure actuator have same repsonse>?
Well, If Blackkers is getting good response using the same turbo then you should too. Just make sure the internal gate is shut and preloaded. and yes 20psi is lovely, baby it till it gets tuned, it should be all good :yes: .
  • Like 1
I usually slot the actuator bracket fitting holes, and that makes the actuator pre-loadable. Usually seeing around 15psi of boost once that is done.
Some updates. This is result of a OP6 high flow that I've done for Unique Auto Sports in NSWs.
R33 GTST stock engine with usual bolton supporting mods, PFC, pump 98 fuel. Final result of 278rwkws @ 18psi:
And a prototype turbo for Jet_R31. its the biggest possible turbo that we can make that fits into a T3x turbine housing. Hopping to see 600rwkws on his built RB30ET engine.
  • Like 2
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
