And by the way, I've made some custom exhaust wheels that is for the GTR OEM high flows. They are engineered to support 300 ~ 350awkws region on pump fuel and response will have similar to stock twins. My car's waiting for bits and pieces, so if any one is interested to evaluate please let me know, I will put a special offer for $1200 on both turbochargers.
-9 alternative at half the price of Garrett items Edited by Blackkers
fk me i wish i didnt have brand new -7's...
Hows the R34 development hack going Stao?, You havn't dynoed a SS based version of the ATR 45 SAT on a rb25 for that yet have you, only the normal ATR45 SAT version?
cheers
darren
Stao, which version did I end up with? The SS based or normal ATR45 SAT?
The SS based SAT made too much torque which my current clutch couldn't hold it. But let me know if you wish to try, expecting to see around 450rwkws mark.
  • Like 1
took about two weeks to get my order of a PWR intercooler delivered. It came with a pretty good looking box (they asked $11 additional for that box), polished tanks and pretty neat welding:
Compare to the Takashi, end tanks looks quite similar, except PWR is hand welded and Takashi is one piece die-cast.
However the core interior is quite different. The PWR's cooling fins are neatly 45 degrees angled and dead straight, while the Takashi is all over the places:
So hope to see a difference on the dyno on Monday, and will update results when ready.
  • Like 1
Nice video footage. :)
This is a set of rather unusual high flow jobs. Pair of high flowed 2860-5s into ATR28SS15. Its going to a Rb30det engine with Rb26 head. Hopefully they will solve the back pressure issues currently experiencing with GTRS turbine wheel. One more thing that I'm alittle concern is the back pressure in the exhaust system as the ATR28SS15 is ideally made to run on a single 3 inches turbo back system, that GTR is pretty good of having 4 inches turbo back exhaust, still have to be shared with two turbo how ever. I've made some oversized thrust collars for that purpose, hopefully be seeing close to 500rwkws with those once fully running.
Can't wait to see results of this, a guy over on AUS300ZX made 492rwkw on his GT2860-5's so i want to see how much your version can make.
This is the lastest results for our evaluations on intercoolers using 173,000KM fully standard Rb25det Neo motor and our ATR43SS2 Rb bolton turbocharger. The result is intriguing, and I have personally never ever thought it would turnout this way.
The test car (r34GTT) has:
1000cc Bosch injectors
Walbro 470L/H Fuel pump
Hypergear ATR43SS-2 internally gated bolton turbocharger
Adaptronic Plugin ECU
Just Jap's Front mount cooler piping kit
Just Jap's Turbo back 3 inches exhaust
100 cell cat (don't know the brand)
Tuned by Chequered Tuning
Pump 98 fuel
Pressure monitored from both inlet and outlet of the intercooler
Nothing has been changed on the car apart from the intercooler it self. The result indicates the effects of cooler change, this may or may not apply to other cars apart from mine, it obviously does not mean you should be spending more money on your cars, I'm not promoting or in favor of any manufactures.
Result are based on very similar boost levels:
Takashi 600x300x68mm cooler:
267rwkws @ 19psi after cooler or 23psi before cooler
Takashi 600x300x100mm cooler:
278rwkws @ 20psi after cooler or 24psi before cooler
PWR 600x300x81mm cooler:
303rwkws @ 20psi aftercooler or 22.4psi before cooler
295rwkws @ 19psi aftercooler (blue is from Takashi 600x300x100mm cooler)
  • Like 4
what Intake Air Temps are you registering?
I wonder if it's more so the intake temp that's promoting more power rather than flow, etc.
That's what it was thinking and asked on fb about temp changes pwr cold to touch. Edited by Badgaz
Other thing it might be worth mentioning is the PWR's core has no inner fins. They are just straight triangular tubes. Which naturally less resistance. That shown up on the power and torque curve after 5000RPM, engine is definitely getting more air there.
Fascinating stuff, Stao. Love the detail you're going to, it is a puzzle. Would be nice to see intake temps logged as well, although the PWR straight fins / less resistance if anything I would expect to see higher intake temps. Possibly on the NEO, flow matters more than temp. Maybe this is to do with the camshaft and how efficiently the cylinders fill/scavenge. The Neo certainly seems like it loves to breathe, I noticed a "seat of the pants" improvement even from having a straight through muffler but I couldn't tolerate the noise so had a triflow put in.. but I'm guessing the JJR exhaust is some straight-through canon type thing (ugh).
PWR uses a design borrowed from the VR4 and EVO's over a decade ago. The little nodules on the inside of the core actually create a larger surface area over traditional intercoolers which cools better whilst increasing flow capacity. The Delta fin(Apexi Style) of the Takashi reduces flow over a comparable 68mm core which also lets it down.
Best cooler to date I have tested is the ARC R Twin entry, flared bell mouth style inlets, flow through knife edged tubes(outside air for radiator). If only you could use the EVO/PWR style core with the ARC core (inlet air) bell mouths you would have it all so to speak. Pity they are almost impossible to find these days.
Matt
Edited by BoostdR
Matt
Do you reckon replacing a Takashi 68mm core with like a JustJap 78mm will cause any differences and be worth it ?
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
