I have a mate who's drift car (with RB30/26DET) puts out 450 rwkw through a HDi intercooler. So sure you can force the air through the china cores to make reasonable power... but it begs the question, how much extra power would it make with a decent cooler? At the same time the tune would probably be safer due to lower intake temps.
Edited by Ryno
has any body tried water spray to increase core cooling? I've seen this make good power difference in the dyno.
I have a mate with a R33 GTS-t with water spray hooked to his IAT sensor.. smart, but you need to always refill it on the track and 1x 2L washer jet bottle doesn't last a full session on the track.
So better to get a more efficient core to start with.
Hopefully when funds permit next year, I will be going straight up to a 100mm Plazmaman core.
I built a system using the Autospeed intelligent water spray controller (which is actually a very clever piece of kit and worth the money) a largish water bottle from a Cordia and a good Bosch windscreen washer pump from a Commodore. Plus a very good atomiser from Spraying Systems. I installed that on my original R32 sidemount. Running the RB20 at 14 psi was enough to make the sidemount marginal - it would heat soak if you drove the car hard. The water spray did an excellent job of keeping the cooler's temp down, and the spray controller made very parsimonious use of the water, so the bottle lasted weeks of street driving. This was all pants-dyno stuff, so not particularly scientific.
When I upgraded to a front mount I could not tell the difference between having the spray working or not, so clearly the cooler was good enough on its own. So I took it all off the car.
if anyone wants my scotty_nm35 intake it's for sale with all silicone joiners/reducers to fit either stock airbox -> hypergear SS2/G3 turbos or pod..
For Sale thread & Photos:
http://www.sau.com.au/forums/topic/461780-fs-syd-r32-r33-scotty-nm35-alloy-intake-pipe-with-4-3-silicon-reducer-good-for-low-mounthypergear-setup-pod/
No point
a small wmi jet works much better..
and i bet anything you would like ..using a china core with wi is better than a expensive core heatsoak wise aswell. Was cheap aswell when dollar was good
cheers
darren
No point
cheers
darren
I'm on E85, so doesn't "really" make a difference in terms of knock.. but because it's not as cold means you make less power and also I have an IAT table that corrects the injection table so it doesn't run rich as crap.
I'm happy to spend my money where it's needed and happy to get rid of my China Racing products (sound racist, but I'm half chongers myself hahahaa)
  • Like 1
Im using a plazmaman 76mm core on custom returnflow piping... not hitting any restrictions caused by it as of yet 324kw running 16psi on flex e70... maxed out injectors stopped me running more boost or 284kw 18psi on 98
No point
Not anymore unfortunately. I want another kit to put on the diesel family wagon but not with today's prices.
Best work as a twin, can use two ATR43SS2s, similar to Chequrered tuning's 650rwkws setup. If it has to go Single ATR46 is fine working with two 45mm gates.
another quick question.
Can the ATR45 be supplied with braided lines to suit rather than attempting to make the standard lines fit?
+ pricing
I would also be interested to know - I guess it would be just as easy to get the earls kit though or get custom lines made.
Will wait for Stao's response.
  • Like 1
ATR45SAT comes with braided oil feeding line and uses OEM oil drain. Including the manifold spacer this turbocharger is $1350 inc GST internally gated.
The water lines you can use Earles kits for around $130 from Pirtek. Or you can use push on hoses and fittings, which comes to around $40.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
