I have a mate who's drift car (with RB30/26DET) puts out 450 rwkw through a HDi intercooler. So sure you can force the air through the china cores to make reasonable power... but it begs the question, how much extra power would it make with a decent cooler? At the same time the tune would probably be safer due to lower intake temps.
Edited by Ryno
has any body tried water spray to increase core cooling? I've seen this make good power difference in the dyno.
I have a mate with a R33 GTS-t with water spray hooked to his IAT sensor.. smart, but you need to always refill it on the track and 1x 2L washer jet bottle doesn't last a full session on the track.
So better to get a more efficient core to start with.
Hopefully when funds permit next year, I will be going straight up to a 100mm Plazmaman core.
I built a system using the Autospeed intelligent water spray controller (which is actually a very clever piece of kit and worth the money) a largish water bottle from a Cordia and a good Bosch windscreen washer pump from a Commodore. Plus a very good atomiser from Spraying Systems. I installed that on my original R32 sidemount. Running the RB20 at 14 psi was enough to make the sidemount marginal - it would heat soak if you drove the car hard. The water spray did an excellent job of keeping the cooler's temp down, and the spray controller made very parsimonious use of the water, so the bottle lasted weeks of street driving. This was all pants-dyno stuff, so not particularly scientific.
When I upgraded to a front mount I could not tell the difference between having the spray working or not, so clearly the cooler was good enough on its own. So I took it all off the car.
if anyone wants my scotty_nm35 intake it's for sale with all silicone joiners/reducers to fit either stock airbox -> hypergear SS2/G3 turbos or pod..
For Sale thread & Photos:
http://www.sau.com.au/forums/topic/461780-fs-syd-r32-r33-scotty-nm35-alloy-intake-pipe-with-4-3-silicon-reducer-good-for-low-mounthypergear-setup-pod/
No point
a small wmi jet works much better..
and i bet anything you would like ..using a china core with wi is better than a expensive core heatsoak wise aswell. Was cheap aswell when dollar was good
cheers
darren
No point
cheers
darren
I'm on E85, so doesn't "really" make a difference in terms of knock.. but because it's not as cold means you make less power and also I have an IAT table that corrects the injection table so it doesn't run rich as crap.
I'm happy to spend my money where it's needed and happy to get rid of my China Racing products (sound racist, but I'm half chongers myself hahahaa)
  • Like 1
Im using a plazmaman 76mm core on custom returnflow piping... not hitting any restrictions caused by it as of yet 324kw running 16psi on flex e70... maxed out injectors stopped me running more boost or 284kw 18psi on 98
No point
Not anymore unfortunately. I want another kit to put on the diesel family wagon but not with today's prices.
Best work as a twin, can use two ATR43SS2s, similar to Chequrered tuning's 650rwkws setup. If it has to go Single ATR46 is fine working with two 45mm gates.
another quick question.
Can the ATR45 be supplied with braided lines to suit rather than attempting to make the standard lines fit?
+ pricing
I would also be interested to know - I guess it would be just as easy to get the earls kit though or get custom lines made.
Will wait for Stao's response.
  • Like 1
ATR45SAT comes with braided oil feeding line and uses OEM oil drain. Including the manifold spacer this turbocharger is $1350 inc GST internally gated.
The water lines you can use Earles kits for around $130 from Pirtek. Or you can use push on hoses and fittings, which comes to around $40.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
