Maybe kind of weired questions, but what do you guys do with th bov, use stock one, block off or replace. And if you keep using them, aren't there some leaks ?
I bought a Turbosmart Kompact PB from Scotty's customs. Works a treat Stao also recommends changing stock one.
People also say you can use the GTR one
Using stock bov, nothing wrong with the GTT one at this power lever (sub 300).
Do those earl kits suit GT30 etc turbo's or only for stock replacement? and do they have the required restrictor or is the restrictor in the turbo already?
Mine started to leak after around 6 months, mostly driven on low boost (284rwkw at 15psi) had to replace with a GFB plumb back and adjusted the spring tension to max. Made a massive difference. For a small amount of money I'd say its worth upgrading
delete BOV, done :)
Sounds mad too and gets the bitches - HWP may or may not love it though :P
Disregarding the legalities behind decat, Stao on your test cases did any of them have a cat converter? I would be interested to know how the exhaust tee compares/ed to the decat - I recall talking to Johnny and he mentioned 10kw gain just by going decat IIRC.
Edited by kingtube69
Water fitting on the ATR4xx turbochargers are in M18x1.5 same as OEM.
To get full power from the ATR45SAT internally gated version. It needs to be either in a 4 inches exhaust or a 3 inches pipe with 2.5 inches tee off factory front pipe. Exhaust on and exhaust dropped makes a noticeable difference in power.
mine leaked straight away at 260rwkw through a auto..it leaked so much the external wastegate didnt open..lol
still made 260rwkw at 16psi on 98 octane with a hypergear g3 and a auto
cheers
darren
Edited by jet_r31
Hi All,
Just an FYI that Stao and I came across - I tested having the boost controller hooked up between the compressor housing and the actuator and then the charge pipe and the actuator. It seems that having it on the charge pipe I can achieve greater levels of boost across the board. I.E couldn't make 1 bar in first or second gear now it makes this and peaks at 18psi in third and so on easier now.
Quoting Stao's response after my test:
This experiment means there is quite a bit of pressure drop across the cooler, so the high pressure side would be opening the gate earlier while the lower pressure side will be holding the gate shut for longer, hence the boost gain. This is a good result, you might want to mention that in corresponding threads.
Hope this helps someone else with the same turbo (ATR45SAT on RB25)
  • Like 1
cheers
darren
Kind of weird this matters, because a decent boost controller or even better, a decent ECU, manages the boost pressure with as reference the Map sensor, so even with a boost drop over the core, the boost controller should add a bigger amount of duty cycle at the boost solenoid leading to the actually boost pressure you want to entering the engine ... IMHO
Hi All,
Thats because the pressure differences between your cooler, helps someone with the same cooler kit maybe. Makes no differences on my truck cooler :laugh:.
It is best sourcing waste gate pressure after throttle body, that gets rid of the variations of cooler kit.
You mean after the intercooler but before the throttle body, ie cold side :)
Taking pressure from the plenum to control either your internal or external gate will cause issues.
Yep makes sense now I think of it. Most people run the blitz coolers (like mine) so i would hope it helps a lot of people. What cooler are you running? Pics or gtfo :P
Charge pipe pre throttle body yielded the best results for me - Boost pressure is now about where I expect it to be but still suffering pressure dropping. I'll confirm by running the boost gauge pre cooler this weekend.
Just an update, I still haven't removed my old turbo.. I am so lazy these days..
New Year's resolution, remove turbo and send back to Hypergear for an upgrade :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
