Im using a map sensor, will it still mess with it Stao?
Edit: and whats wrong with stock airbox?
No it won't, and stock airbox doesn't flow too well.
I pulled mine off and ran a straight pipe with no filter and made an extra 13kW on the dyno.
  • Like 2
-_- back to stock airbox it is
Nothing wrong with the stock airbox, just retarded comments from people who should know better.
Not everyone cares what happens on a dyno with the bonnet open. Some actually drive on the road.
Something interesting I found out today - Put a pod on my car for all the choo choo sounds (not really) but it makes more boost easier in all gears... 1.10 pound in second easily and full boost in third easily.
I had the stock airbox on but I put the pod on with the factory snorkel for cold air feed.
A clean air filter element would likely do that. What are you trying to prove?
Hot air pods are ghey, I have never seen a decent race car running one. It's all about the cold air induction, and I am yet to see one better than the stock airbox on a Skyline.
IATs matter the most post intercooler and not pre.. you could have chilled air being compressed and fed through non efficient intercooler and you'll make less power, prone to more knock than a setup that's compressing super hot air and flowing through a very efficient intercooler.. your car will make more power, will have a lower chance of knocking.
So yeah, pod or airbox does not really matter.. However for cars running a AFM, AFM voltages may change going from an airbox to a pod setup.
Naah, both do mather... If the pre intercooler iat's are lower, the post will be much lower to. So a decent pod, not mounted in a box or shield or whatsoever will imho have higher post intercooler iat's then a stock airbox, on the other side throttle respons could be a bit better caused by less restriction from a decent pod
Also, turbos are a volumetric device. If the inlet density is higher (ie, from cooler air) then the outlet density is also higher. What that means is that 20 psi of boost starting from 20°C outside air temperature, is not the same as 20 psi of boost starting at 60°C underbonnet temperature. There is a fair bit more air in the cooler case than in the hotter case. And you can't just wind the boost up to compensate, because that of course just makes the output hotter, which is detonation causing, etc etc blah blah blah.
understand, however let's say this, for both (hotter air intake vs. cooler air intake) the:
  • post FMIC IATs are the same, let's make up an arbitrary number 40 degrees Celsius
  • boost source is tapped for the actuator pre throttle post intercooler, let's say post intercooler it's measured at 1.5bar
  • altitude is the same, so 100kPA (probably useless variable to have in this hypothetical)
I doubt there will be a massive difference in power produced, yes maybe a tiny bit difference because now the turbo needs to spin just that little harder to make up for the lack of pressure (due to air density, pre intercooler) so the EGTs might me a little higher or a lot (depending on how much harder the turbo needs to work).
If you were looking at logs, EGTs, turbo turbine RPM yes there might be a "huge" difference, but the end result wouldn't be much different from a pod filter without shielding to a pod filter with shielding.
Not sure if I am even making sense to the masses anymore.
I get your message. I just think that a every single one of your little justifications is lost power that you could have had for free with some cold air fed to the turbo. Most of us are pushing something up against its limit when working these engines. Whether it's the turbo itself, or ex manifold pressure, or inlet temps, or maxxing the injectors.....regardless of which of those, you could squeeze more power out of not having something else working against you as well as that limit.
  • Like 2
it is also about how much air could be shifted. Vs stock turbo to a GT40 at at a bar of boost, compensate half the timing to the GT40 it still makes more power. As for the same reason of why people don't install factory exhausts on a high powered cars. If the stock air box is only made for 250HP, it will obviously restrict and affect drive ability on a 500HP setup. A well made pod enclosure or a custom cold induction system will definitely help getting the best of both worlds.
The roller dyno works fine in setting up the correct ecu parameters. Because the data output do depend on the rolling object, when comes to preciseness for developments and research its not that accurate. As the firmness of the tire, the size of wheels, position of where the wheels are parked and the tension of strap can all affect its power output.
When shaping turbo wheels for very specific applications. the mm in alterations will slightly alter output and we must to be able to compare those changes. Thas is what a hub dyno is good at, without variances the rolling object, the output is extremely consistent and accurate.
There are specific HP determination equation for different regions, assume the same equation is used, with test vehicles perfectly set, the HP reading between dynos should be very similar.
There are many other variants that could alter the performance of a engine, which I have specifically picked and tested those areas using RB engines, data has been recorded and could be found on index page 1.
I have always wondered in regards to the airbox debate. I don't quite understand why your engine bay temps should be so high when the car is moving. Even with a pod, I can't see air temps being an issue when you are travelling at 80 km/hr. Sure when you are stationary they will rise, but temps will quickly be restored as soon as there is some airflow.
Example
If the engine bays air entry is a 1m x 1m and the engine bay volume is 2x2x1m then you have a surface area of 1 m squared and a total volume of 4m cubed
Approximation suggests
@40 km/hr you have 11 m/s of air volume = 3 air changes per sec
@80 km/hr = 6 air changes per sec
@120 km/hr = 9 air changes per sec
Even at 70% efficiency, that is still a lot of air moving through the engine bay.
I can't logically see how a pod could cause the issues that are being suggested even though a pod could benefit flow at higher demand conditions.
Not saying I am right, but my basic maths questions the opinions.
Most of the air in the engine bay comes through the radiator. That adds heat to it. The engine actually consumes quite a large amount of air, even relative to the air flow through the bay. So even though the air intake (pod say) is in the front corner of the bay, it will suck a lot of air from everywhere, including past the exhaust manifold and turbo.
With respect to the moving vs stationary point.......you often want max power when you've been stationary at the lights or similar.
Compared to most other things we do, a proper cold air intake is so easy to do that I don't understand why it's even an argument. In my R32 I put a 100mm duct into the dirty side of the airbox from the front cavity where the SMIC was. Intercooler pipes still go through the original holes.....no-one notices that it's modded.
Edited by GTSBoy
New manifold, it's currently in the post :)
Will be bleeding exhaust pressure/gas at the manifold instead of the turbo housing to control boost. Should be able to keep the exhaust pressure down and heat down which equates to more power.
HAVOC Fabrication modified manifold.
Old setup turned blue after constant track days, clearly shows EGTs were more than not friendly (even on E85).
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
