The Power to boost behavior of the RB20det is similar to an SR20det on stock cams. like the G2 and SS15 versions works pretty well on RB20det in a T3x .64 rear that has been made to suit Rb20det's T3x print with 6 bolt dump.
There are very few Rb20dets around so its unlikely I will be invest into it at this stage.
  • Like 1
2016 version of SS2 has many changes made to earlier models. The difference in end result would be a combination of alterations made. Ceramic ball bearing system makes difference in throttle response and becomes very apparent when working with low CPR, None VCT engines as well as cars with Auto transmission. It is definitely recommended for that Cosworth engine.
thanks for that Tao.
so the SS2 with CBB would be more responsive than the ATR43g3sat with cbb?
No its not. but current version did make more power externally gated. Im doing more developments into that at moment. But I dont think I can get any better.
Car is going on the rollers soon, just got my exhaust system modified again :)
Car still runs a cat, still smells great and makes less pollution than any VW out there (jokes). However you see what I did there? haha :ph34r:
It's 3.5" turbo back (all stainless), runs a 3.5" cat, 3.5" mid muffler, 3.5" resonator and a 3.5" rear muffler, however there's a stupid 3" restrictor or smaller right were the tip starts.. broscience tells me the EGTs are much lower there and the exhaust gases "should" be more dense.... let's see on the dyno.
Yes that's right no more screamer.. on the up side the exhaust is so quiet all I hear is spool and dose :wub:
Big shout out to Grub and his team @ Impossible Fabrications at Moorebank.. he built whatever I drew up/dreamt up and did it quickly and mind you cheap too!
  • Like 2
Need to redo the wideband wiring, it's just there temporarily.. there isn't much room for it because of the le-hectic wastegate plumb back hahaha
Mr EPA won't like it, but Mr EPA can do the gas test and dB test and I'll pass (well pretty sure I will) lol
Is that the hks exhaust i sold you
You should of cut the restrictor out
Its a easy job and could have got them to reweld it
Just the welds around the exhaust tip you have to grind off and it slides out 1 piece with the restrictor
hahah yep.. I launched the mid muffler and the front section of the pipe work..
Tried that trick you said, the internal tube has been tacked into the meshing inside the muffler... chopped off the entire tip and all, wouldn't budge.
I'm going to get a slide hammer and go to town with it.. it no luck, I'm throwing that muffler.
With my old fujitsubo exhaust was like that and my kakimoto one is like that
But im just going to cut the restrictor with a small dremel and just remove it from the diff back and it should fall out as the piping is 3 1/2 inch and fairly straight
So i dont have to reweld it but ill leave it for now as it keeps it fairly quiet and shouldnt be much of a restriction at <200kw
Hks must be different
Logs to come, but the motor and turbo wanted to make more power but I stopped adding more timing and boost.
So yeah, stock unopened motor 1.75 bar boost, 1.5 bar by 4100rpm and an effortless 372kW :)
No more screamer, car even runs a cat. Stock intake plenum, stock modified exhaust manifold.
Many thanks to HyperGear for the upgrade and Mark at MRC for coming in on a Saturday to let me use his dyno!
  • Like 4
Hahaha yeah man, drove it home after I tuned it. It's street registered :)
I actually stopped at 360kW then decided yolo, add more boost lol
The SR20 I tuned afterwards was horrible, full boost at 5.2k has rubbish BC cams that are useless. I'm going to help the owner take them out and bin them.
Wut. Next you'll be telling us you have a recirc.
Sadly has decreased, my old SS2 dosed better :(
But, still doses nevertheless lol
You're gonna have to change your username here to 'Dose Pipe Sutu'
  • Like 2
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
