Thanks so much for the info! I've emailed them.
On a side note , now I'm not sure if it's mapping issues or vct because after plugging in, I'm still hitting boost late at 4k ish. And now car feels heavy at 2-3k rpm.
21u should be all in by 3.5k in 3rd and 4th gear when loaded up.
Stock actuator. So 7 psi
I believe jet was asking if you've pre-loaded up the actuator... also when the RPM was graphed, was it derived from road speed or through an inductive pick-up?
Some videos from last weekend. This is 1JZGTE none vvti engine powered R31 Wagon running our ATR43G3SAT Ceramic ball bearing turbocharger making 330rwkrws on E85 fuel. Car Owned and Driven by Jason F.
  • Like 1
ATR43G3SAT in Ceramic ball bearing is the most responsive one out of all. The TD06SL205 in 10cm is the next and ATR43SS3 is the least, but how ever made the most power.
ATR43G3SAT is a very different turbo to the standard G3 with different wheels and housings all together. Dyno reading shown it is more responsive then a GT3076 or any kinds of a TD06. Below is CBB version, internally gated, on stock manifold, P98 fuel built as a bolton turbo.
I have trailed many other prototypes in similar kind and this particular one is the far best.
Other thing worth mentioning is Tomei cams on RB25det didn't do much good part from adding 250RPM worth of laggier, which I ended up converting it back to stock. and still made 431rwkws.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
