We didnt up the boost as the current exhaust is a restriction so more boost currently doesnt = more power. Im really just after more mid range
I wonder what a atr43 g3 sat with a .64 t3 rear would be like on a sr20 then..
Cheers
Darren
There is an custom version made for SR running in .64 rear housing. I'm in the process of engineering an ceramic ball bearing chra to suit an short T2x shaft and bearing housing, which also means all the TD06 can be converted using the same ball bearing assembly to improve throttle response. I'm considering of doing one more round of SR20det development with a stock standard motor, hunting for the right car at current stage also.
Even there is no VCT I should still can engineer an ceramic BB turbo to reach 200rwkws @ 4000RPM that makes over 340rwkws on E85 fuel. Below is result from Jason's 1JZ None VVTI engine running inside a R31 wagon. car made 340rwkws on 23psi externally gated, 200kws @ 4000RPM:
Video taken from last week Calder raceway. Chasing Manuel's yellow R33 GTST, Excellent battle footage of ATR43 G3SAT 1J VS SS2 RB. :thumbsup:
  • Like 2
Yea think i seriously goingnto consider one in the next 6 months looking for that 200 plus at 4k and 350 ish you td06 looks the goods
SS2 or the new G3SAT will do it.. I make about 240kW at 4k and near 7k it's at 370kW
  • Like 1
Aww damn, be interesting how it goes then when I bolt it up. Got it quite cheap. If it doesn't make any decent power then I'll save up again for a different turbo set up from the hyper gear range
Rear wheel looks like standard size.
Gap between wheel and iwg flap is huge
Rear wheel is defs bigger than standard wheel, look at adms15 rear wheel in his standard turbo against the post I did. Defs a difference.
I have found out who the did the hi flow and as it turns out it's been done by gcg
Let us know how you go
Got the same turbo by the looks of it
What one do you have ? U got a dyno sheet posted up ?
I thought you said you went through the dyno thread and this thread, didn't look hard enough eh? LOL :)
here:
http://www.sau.com.au/forums/topic/261613-hypergear-hiflow-service-continued/page-583#entry7731137
and
http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-54#entry7731169
Oh yez.. plus a video haha:
  • Like 3
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
