  l0WRB said:
any update stao on that rb25det gettin tuned? the one only running 9psi for now
He drove off to Adelaide, probably come back in 2 weeks to finish off the tune. I will postup result once its done.
Ok. This is our latest dyno result based on a ATR28G4 in a .64 T28 rear housing running on a build CA18det running 98 fuel. Car made 316rwkws at 24psi at this stage ( Note: see how the power curve is still rising. ). going to do a final tune in few days. This turbo would be making some mad power on RB engines using .63 rear housing.
ATR28G4 would be some thing similar to a GT3076.
Its my daily car. I drive drive it around to deliver turbos. lol
CA's modifications: Forgied pistons, Split fire coils, Nistune ECU, FMIC, 700CC injectors, Z32 AFM, 256dur/8.9mm cams, Tomei adjustable cam gears, ebay manifold and 3inch exhaust. Every thing else not mentioned are stock.
That looks good. OP6 is still small. You need .63 rear. I can get one machined for for $250. But you need to make a new front pipe. Check That exahust place next to Trents.
  • 1 month later...
The guy got EPAed and defected on the way back from SA. its going to be a while before it go back to the dyno. Hoo and by the way there are plenty of ATR43's progress. The laser cutters finally got our flanges ready. So just matter of putting them together now. should have 2x samples done by weekend.
Its similar sort of CHRA. Rear housing is different. It will be a.63 Rear housing. that we made our selves. I'm plaining to make 4 different types of CHRA with 2x different sized A/R housings. which are powered from any thing at 230rwkws to 330rwkws depends on driving ability. I will post some photos once I get the housings finished.
  SS8_Gohan said:
did an E85 tune Stao..
Since you got trent to tune it im assuming your local, where around the dandy/frankston area sells E85?
  SS8_Gohan said:
no one does, i drive to Hoppers. Car runs 100% time on E85. Jerry cans ftw! :(
Hopefully some one starts selling it soon, im not as dedicated as you are :)
Whats the price of it now?
Edited by W0rp3D
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
