This is a prototype ATR43 G4 520HP CHRA. It runs on shortened bearings and weigh reduced turbine for maximum response. engineered to produce about 300rwkws at 20psi on .63 ATR43's turbine housing using RB25det engine with supporting mods.
The smaller one on the photo is ATR43 G1 350HP CHRA. Its made for 240rwkws with excellent street response.
Compare to ATR28G4 it has lighter turbine with shorter bearings. So it should have slightly better response. I might update this CHRA into the ATR28G4 once its been evaluated.
Turbine housing is getting made. I'm going to swap this 2x with my existing high flowing customers. probably Geraus and SS8_Gohan for some dyno and evaluation results.
For time been we will still be using proven ATR28 CHRAs. Price wise I don't know at this stage. depends on how much it cost to build the rear housing.
hi,
i skimmed through quickly but didnt find the exact answer i was looking for.
what turbo would you suggest is the most efficient/responsive for a Rb20(r32) wanting to make 240-250rwkw while keeping the stock manifold, but being externally gated.
thanks.
hi,
thanks.
i went with a ATR28G3 with 0.63 internal gate rear for my rb20... i'm looking for a tad more power than you
so maybe look at a ATR28G2
hook us up Stao :P:ninja:
we going to need new dumps? and am i going to have to run stuff in again... done so much friggen running in with this car :P
EDIT: so are you saying these will be laggier or potentially, they might be a little more responsive and make a bit more power?
Nice love the pointy wheel. Hopping to see the complete turbo and some results soon.
ps.
would this punch a whole on my foot if I drop it upset down? :ninja:
Edited by kwickr33
Today got the turbine housing made. It is .86 in a T28 which is equivalent to a .63 in a T3x.
It is bolt on to stock T3x manifold and 6bolt dump.
The Very first ATR43i 520HP G4 in T3 .64 Turbine is complete:
We'll be making few more different A/Red turbine housings in the next few weeks. We will also be engineering a 650HP profile CHRA to suit a .84 Bolton Rear housing.
Well stock turbo won't make 520HP. Bigger turbos will creat more lag. This is a G4 profile, made for 300rwkws.
We also have this in G1 and G2 profiles which are rated 350HP and 450HP. The G1 would have very similar response as the stock turbo to produce max of 240rwkws, G2 is about 300RPM laggier but but its good for upto 270rwkws.
Price wise This turbo is $1300 to complete. With normal Turbine housing which comes out in a Vband rear is $1050 internally gated. or $950 externally gated with a 5 bolt flange.
didn't i have a G2 originally? that was about 230rwkw at 15psi -
gotta remember, "most" people won't be bolting these onto built engines (IMO) - they'll chuck em on, run 15/16/17psi and that's probably about it. I'm only running a bit more boost because of E85, otherwise, 17psi would probably be my max.
will give you a call/email asap about the .63
Yes but that was in stock R33's turbine housing. Now they are running in a .63 T3x rear housing, The spec of it is very similar to a GT3071. So it should make around 260rwkws at 18psi of boost on 98 fuel
do you also make this turbo with an externally gated rear housing?
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
