This turbo is far from bolt on the water/oil lines are no where near fitting even when clocking the turbo while its on the exhaust manifold.
I sugest in the future you advise client how much of a f**k around it really is and supply custom lines with the turbo.
And no its not my lack of mechanical know how. If i can swap in a new rb26 in a 32 gtr with out a hoist and with out dropping a gear box then this semi bolt on turbo should be a breaze
Well, you must use braided oil line that is supplied. Do not use your stock oil line, It wont fit, and will starve the turbo. Braided line runs from the other round of the turbo to block. the drain pattern matches to your OEM pattern.
We remove and fit in average 2 skyline turbos every week, this is 3 hours job which we only charge $200 to carry out or $250 onsite.
I removed and fitted mine in my self, I'm not mechanically minded at all. Took me 5 hours, and most of time was spent on trying to get rusted bolts out of the manifold and dump. The metal water line to chassis side is pretty easy to get on, With the L shape one that is on engine side you need to force it backward to secure the hollow screw.
Its a standard Garrett T3x bearing housing with M18 x 1.5 fittings on both side. We also use on all our high flows. Braided water lines are not required to fit it.
Here I've attached a photo. Note the oil feeding port is directly above the screw pointed. Once rotated to this angle, It will line up with all fittings.
Turbo Cran mentioned is a ATR28G4 in .82 T3 turbine housing. unfortunately back then they were sent out in T28 bolt up position. Current ATR43 Gxs have had the CHRAs rotated to photo above before sent out.
Cant wait for my new turbo 3582 .69 exh with 50mm gate and anti surge slotted .7 front cover
ill let u guys know how i go once its tuned after the new yr
gonna be a bit of an upgrade over the old kkr480 lol wonder if 400rwhp is out of the question mmm
thanks 4 ur good service stao hope to see the turbo in the mail soon!
Here are two photos of your job. Turned a KKR480 to a sleeve bearing 3582 in .70 front with Anti surge slots and .69 rear. I'm pretty happy with way of how the angled slots we drill came out.
My Camera wasn't very good. Please upload few photos when you get it. Cheers.
Few new projects and updates for 2010:
First of all few of you already know We've started developing VARA project in Mid dec 09. Which allows us to change your turbine A/R to what ever we need it to be. Means we can now high flow your stock R33 (yes your stock 2IU turbine housing not OP6) turbos to produce 270rwkws if need to. So we are no longer boxed by the flow limit with some smaller turbine housings.
2ndly as we all aware that smaller turbine housings gives us better response but not good up top. with our Variable Air Ratio (VARA A: actuator controlled) turbine housings. We can start off with a .42 A/R till 7psi and have it increased to 0.82 on 20psi refer to boost increase. Means you can have 300rwkws with stock alike response. This response is also adjustable with a bleed valve. This method has been used on few turbocharged Porches, we will be intergrating this into Nissans.
3rdly We will be building .60 compressor housings with stock size inlets and out lets. So people are no longer required to get any "Kits" as it bolton to your stock every thing.
I will be posting photos once I get back on the 15th of Jan.
Happy new year every one.
Sounds effing excellent!  :)
When do you expect these services to be available, will you be putting up rough price estimations?
Might be a good time to pick up a cheapo blown 33 turbo  :D
That's awesome news...when do you expect the VARA turbochargers to be available? Any idea on pricing? I plan on high flowing my R33 turbo with you guys soon so if you need another test mule...
Can this be done with the standard housings - ie: you just change the CHRA, or does this require something more special?
and you can turn KKR turbos into something worth using!?
Only original part from my kkr turbo he used was my exhaust housing because it was already modified to suit 50mm ext gate
rest of it is all brand new and i must say looks very very sexy! :P
in the stage of bolting it up, waiting on spacer plate and gotta get water lines etc
I should have my ATR43G3 fitted up soon....well by soon i mean when ever my bloody manifold gasket turns up =\
I got the .82 rear housing...mainly because the car is track only and will spend most of its like above 4k rpm
LOWRB: Please post some photos man. Cheers.
VARA turbine housings can be installed onto any type of CHRAs including Garrett BB once.
The R33 turbine housing A/R increasement is apart of our powered up high flow. It cost $1270 to carry out including GST and braided oil feeding line. High pressure actuators are available for $150 for any one who needs to run more then 16psi of boost.
new gt3582 turbo is fitted up low mounted on stock exhaust manifold
pulled all my hair out i think but finally got there..
ext gate is set to .5 bar until tune on 20th
turbo has a very loud whistle from the surge slots similar to hks to4z and t51r sounds nice
lets just hope it produces some decent power :(
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
