Hi every one. I'm back. Here's the PU (powered up) high flow based on a R33 2IU turbo. Note how we've modified the stock turbine inlet to increase its air ratio. Its running a custom sleeve bearing 3576 CHRA. I believe it can possibly push out close to 300rwkws with external gate.
(This high flow can be done with stock R33/4 turbo's comp housing)
The cost to do this high flow is $1200, and its high recommended to run it with a high pressure actautor at $150 additional.
With the 76mm comp housing it should hit 300rwkws with flate 21psi. We can alter the stock turbine housings even bigger if need to. This one is currently running off a modified gt35 turbine, Thats about the biggest we can stick in there.
Here are few more Photos of Powered Up high flowed R33 turbo with 2IU turbine housing:
Note the difference in volume of modifed turbine housing on the right:
Cant wait to see one come through, if you can find a decent donor car to test it (mechanically 100%) i will be happy to subsidise the tune for R&D.
Damn if only I was in Melbourne :P...
*cough*
Very happy with results from the new turbo (g2), well worth the money. Turbo is installed, and pulls a lot harder through-out every gear. (just ripped a m3 lol)
Excellent product and customer service, and highly recommended.
-I just wish i saved all that money instead of getting gt 3040, spending big money on injectors, fuel pump, z32 tune etc etc just to get done by cops. Now i get similar power, and i mean similar! and all i got illegal is my t piece boost controller. Very satisfied.
Here is 2 pictures of my stock turbo V G2 to compare the difference for everyone to see.
if i had cash id put my car up as a test bed for the new 2IU setup, yet need to many supporting mods to jump so soon.
Cant wait to see the results either way
Have you had it dynoed with the turbo?
That is just awesome. I want, and will buy as soon as my PowerFC arrives :)
How is the response of this comapred to stock? Similar?
It wouldn't be very close to stock given how big the A/R is on it...I'm sure Stao could answer better but I imagine it would see full boost by 3800-4000rpm?
Donor right here! I have an unopened RB25 with circa 100,000km on it, completely standard / never boosted except for an exhaust system and Apexi power intake. Engine receives synthetic oil changes every 5000km :) Recently installed a Blitz CS return flow, have an 040 waiting to go in and my PowerFC is due to arrive in 3 weeks from Japan. Currently sourcing a Z32 AFM and looking at options for injectors. If you can wait the time (about a month at the minimum) let us know if you guys are both interested, as I'll be getting one of these installed and tuned either which way.
Not yet, im running MINES ecu which ill try to keep in there if AFR's are safe (will check on the dyno). Id be happy to run 14 psi, so i wont get the full benefits of the turbo but than again, i want to keep standard injectors etc etc Right now I drive it around on 14 psi with few other mods and car feels great. Once i slap on the cooler, ill check my AFR.
That is just awesome. I want, and will buy as soon as my PowerFC arrives :P
Donor right here! I have an unopened RB25 with circa 100,000km on it, completely standard / never boosted except for an exhaust system and Apexi power intake. Engine receives synthetic oil changes every 5000km :D Recently installed a Blitz CS return flow, have an 040 waiting to go in and my PowerFC is due to arrive in 3 weeks from Japan. Currently sourcing a Z32 AFM and looking at options for injectors. If you can wait the time (about a month at the minimum) let us know if you guys are both interested, as I'll be getting one of these installed and tuned either which way.
Ask trent at status about hiflow injectors, i have a set here that i probably wont be using, will need to be cleaned and flow tested just have not gotten around to it and its looking like im going to be using a 26 head not 25 so side feed injectors will be useless to me.
Hi
Whats the response difference or lag difference between the G2 and the GT3040?
I have a R34 GTT Auto, a brought a GT3040(GT3082) with a .82 rear housing a while ago to put on. Now i think it might lag to much with the auto.
Am thinking of selling, to get the ATR43 G2 or get the original Skyline turbo high flowed.
PS. Only just found this forum topic and have just joined SAU
quick little video 5psi untuned
give you an idea on the induction noise
Sounds awesome mate! Post up one when you get tuned for comparison :)
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
