Hypergear Turbochargers and High flow Services Development thread
Here are few more Photos of Powered Up high flowed R33 turbo with 2IU turbine housing:
Note the difference in volume of modifed turbine housing on the right:
Thats some cool modifications and porting to the housing.
Hi
Whats the response difference or lag difference between the G2 and the GT3040?
I have a R34 GTT Auto, a brought a GT3040(GT3082) with a .82 rear housing a while ago to put on. Now i think it might lag to much with the auto.
Am thinking of selling, to get the ATR43 G2 or get the original Skyline turbo high flowed.
PS. Only just found this forum topic and have just joined SAU
Hi there. If you are looks to make around 230rwkws with excellent street driving ability I can high flow your stock turbo to same spec as a 2530.
Hi
On GT3040, boost wouldnt come on at all under 3500 (which when driving normally is annoying) with G2 turbo comes on about 2700 (only couple of pounds which count when your trying to over take). Full boost 3500 rpm.
LAG:
On gt3040 i would have full boost at around 4500
G2 1st gear 4000, 2nd gear 3500, 3rd gear 3400 5th 3200 rpm.
My opinion:
I was supposed to go for G2 from the start, and mates talked me into getting 3040 instead (M I S T A K E). Unwanted attention, got put off the road. canary.
G2 is better or as good up to 5000RPM, after that not as good but very close to GT3040 IMO. Fully legal, i recommend G2.
LAG:
My opinion:
Hi
Thanks for the info. I will look at selling the GT3082
do you guys do replacment for standard turbos on a r33 gtr? what specs are they and how much power would the rebuilt turbos make? also how much would they cost? sorry couldnt find anythin reading through the pages only found rb25 upgrades nothing for the rb26.
With RB26 we normally high flow them to 2860RS spec. which works out to be the -9 configurations in your stock turbine and comp housings. they would be ok for up to 320rwkws before you need bigger turbine housings. Response wise they feels like the N1 steel wheel turbos. Not as responsive as the stock cermaic wheels.
Photos at:
http://www.digi-hardware.com/gtrturbos.htm
We can build custom .60 A/R comp and .64 / .86 turbine with OEM boltup pattern for those if required.
Hi
I will be looking at getting one in the future
What is the latest prices on the
Skyline ATR43 G2 0.63 turbo?
and
High Flow R34 G3 OP6?
thanks
Hi
and
thanks
ATR43G2 .63 with high pressure actautor and braided oil feeding line we can do for $1530.
To high flow your stock R34 turbo cost $960 including braided oil feeding line. high pressure actautor is additional at $150 each.
Photos at:
I'm curious as to whether you have done one of these custom turbo's for a GTR yet and if so any dyno graphs or similar or info :D
Have done few. Not as many as other turbos thou. Have also driven one. Un-tuned, car pulled hard after 4500RPM but have lost fairbit of response to stock ceramic turbos. its about 300RPM laggier then stock N1 turbos.
Sounds very interesting, what is the price on this for an R34 OP6 turbo?
Convert that into OP6 R34 turbo cost $1000 including braided oil feeding line and oil drain adaptor.
To do this we have to modify T28 bearing housing to suit a T3x pring turbine housing.
I was thinking if you could use the new VARA turbo's that your making in a GTR...maybe not :D
Standard from $800 + GST + oil line $80 = $960
Powered up high flow from $1100 + Oil line $80 + $150 High pressure actautor = $1310
This might be a silly question but is it possible to just replace the standard ceramic turbo wheel with a steel turbo wheel so that boost can be raised safely above 12psi? Do you offer a price for that? Would it still require a different oil line?
We actually build a brand new turbo core with bigger wheels, then machine your stock housings to suit it. We only use steel turbine wheels. So are you actually getting back a brand new turbo inside your factory housings.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
