Here are few more Photos of Powered Up high flowed R33 turbo with 2IU turbine housing:
Note the difference in volume of modifed turbine housing on the right:
Thats some cool modifications and porting to the housing.
Hi
Whats the response difference or lag difference between the G2 and the GT3040?
I have a R34 GTT Auto, a brought a GT3040(GT3082) with a .82 rear housing a while ago to put on. Now i think it might lag to much with the auto.
Am thinking of selling, to get the ATR43 G2 or get the original Skyline turbo high flowed.
PS. Only just found this forum topic and have just joined SAU
Hi there. If you are looks to make around 230rwkws with excellent street driving ability I can high flow your stock turbo to same spec as a 2530.
Hi
On GT3040, boost wouldnt come on at all under 3500 (which when driving normally is annoying) with G2 turbo comes on about 2700 (only couple of pounds which count when your trying to over take). Full boost 3500 rpm.
LAG:
On gt3040 i would have full boost at around 4500
G2 1st gear 4000, 2nd gear 3500, 3rd gear 3400 5th 3200 rpm.
My opinion:
I was supposed to go for G2 from the start, and mates talked me into getting 3040 instead (M I S T A K E). Unwanted attention, got put off the road. canary.
G2 is better or as good up to 5000RPM, after that not as good but very close to GT3040 IMO. Fully legal, i recommend G2.
do you guys do replacment for standard turbos on a r33 gtr? what specs are they and how much power would the rebuilt turbos make? also how much would they cost? sorry couldnt find anythin reading through the pages only found rb25 upgrades nothing for the rb26.
LAG:
My opinion:
Hi
Thanks for the info. I will look at selling the GT3082
With RB26 we normally high flow them to 2860RS spec. which works out to be the -9 configurations in your stock turbine and comp housings. they would be ok for up to 320rwkws before you need bigger turbine housings. Response wise they feels like the N1 steel wheel turbos. Not as responsive as the stock cermaic wheels.
Photos at:
http://www.digi-hardware.com/gtrturbos.htm
We can build custom .60 A/R comp and .64 / .86 turbine with OEM boltup pattern for those if required.
Hi
I will be looking at getting one in the future
What is the latest prices on the
Skyline ATR43 G2 0.63 turbo?
and
High Flow R34 G3 OP6?
thanks
Hi
and
thanks
ATR43G2 .63 with high pressure actautor and braided oil feeding line we can do for $1530.
To high flow your stock R34 turbo cost $960 including braided oil feeding line. high pressure actautor is additional at $150 each.
Photos at:
I'm curious as to whether you have done one of these custom turbo's for a GTR yet and if so any dyno graphs or similar or info :D
Have done few. Not as many as other turbos thou. Have also driven one. Un-tuned, car pulled hard after 4500RPM but have lost fairbit of response to stock ceramic turbos. its about 300RPM laggier then stock N1 turbos.
Sounds very interesting, what is the price on this for an R34 OP6 turbo?
Convert that into OP6 R34 turbo cost $1000 including braided oil feeding line and oil drain adaptor.
To do this we have to modify T28 bearing housing to suit a T3x pring turbine housing.
I was thinking if you could use the new VARA turbo's that your making in a GTR...maybe not :D
Probably not at this stage. They are too small to work with.
Standard from $800 + GST + oil line $80 = $960
Powered up high flow from $1100 + Oil line $80 + $150 High pressure actautor = $1310
This might be a silly question but is it possible to just replace the standard ceramic turbo wheel with a steel turbo wheel so that boost can be raised safely above 12psi? Do you offer a price for that? Would it still require a different oil line?
We actually build a brand new turbo core with bigger wheels, then machine your stock housings to suit it. We only use steel turbine wheels. So are you actually getting back a brand new turbo inside your factory housings.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
