Stao, Are you able to replace the oil seals in a Garrett 3582R? if so how much do you charge for this?
The Oil seal on exhaust side is just a Stainless steel C clip. This part only wears when you have abnormal amount of shaft play or if its submerged into engine oil means you have a flooded bearing housing.
So if you have no shaft play then the only thing I would be checking is the drain or find out why my oil can't drain out of the bearing housing considering I have 20mm drain slot vs 20 thou oil feeding ports.
The other thing which can cause that is from over filled engine. Ie: Oil level in engine sump submerges the drain port which build up oil in side the drain pipe to cause bearing housing flood.
Also does the turbo make any sort of strange noises on power off? Ie. very light zz zz zzzz zz sort of sound?
If do exists and every thing engine side seems to be nominal then you might want to remove the turbo and send it in or take it to a convince turbo service center for a quick inspection.
Few more updates made for the ATR43 and PU high flows .82 turbine housings. They now installed with 33mm wastegate flap working with a 30mm internal gate port. ( 2mm+ for the flap, 1mm+ for the port). Not much of effect with RB20/25dets, but will make lot better boost control for larger sized engines.
Also this is a little unconventional method creating slight boost spike or consistent boost curve upon to red line. fixing the issue of slight boost drop due to actuator's sping strength. It is updated into all ATR43 / PU high flowed turbos, I found it particularly useful for people who's looking to hold 20~22psi with internal wastegate actuator.
Photos showing:
Wastegate can be fully operated by actuator
or partially operated.
This is a photo for people who prefer to DIY their own actuator bracket. This is modification is included as a part of our high flow service. This post is for people who didn't sent in their actuators.
basically drill or file fitting wholes 5mms towards turbine housing. Once done the factory actautor can be pre-loaded or adjusted.
Stao few questions what type of vband clamp is used for my dumnp? i need to get another one quick. also will a r32 actuator fit on my car? i want to lower the boost to 10psi had a little delay in getting injectors sorted but want to start tuning
Its a 3inch Stainless steel Vband. You can get it from your local exhaust places for about $40.
If you run stock actuator you should be able to drop some boost. But ATR43's comp housings doesn't have OEM actuator bracket pattern so installing it on the car would be abit of challenge. Can be done.
what would it mean if it made that sound? i recon my old car may have done that..
Normally means there are small cracks or uneven surfaces on rolling objects. It's the early stage of failing. This noise do gets louder with time. It is recommended to have the turbo overhauled at this stage. It will be very difficult and expansive to overhaul once wheels scrubs.
Oil contamination would be the main cause of it. Run a small inline filter before putting the turbo back.
thanks for the quick answers stao
hey if i was to get an atr43G3 and wanted to run about 18psi on my r34 gtt rb25det neo at wat rpm would it have full boost (18psi)?
how much power do you think it would make with all supporting mods at this amount of boost?
and is a z32 afm a good idea to get first, its the only other thing i need that i dont have..
thanks =)
With ATR43G3 .82 you will get full boost at 4300RPMs. With the current waste gating control you should be able to get 300rwkws on 22psi flat with supporting mods.
In most cases you will get some where between 270~280rwkws on 18psi.
Supporting mods you are recommended to get:
850cc injectors
Z32 AFM
ECU (Nistune or PFC)
Cooler, clutch, exhaust and all usual stuff.
ive got all the usual stuff
ARC FMIC
full exhaust
apexi pfc
oil cooler
clutch
splitfire coil packs
apexi avcr
ive also got denso 670cc injectors not installed yet, their on a custom rail for the r34 GTT, they will b enough hopefully wouldnt they..
apart from the z32 which i should be able to get soon enough
670cc should be fine for that turbo
670cc = 670hp = 500kw (at the fly) - you're running 98 i assume, so those very rough calculations would be about right.
With all the bits installed and a good tune. you will be able to get 270rwkws pretty easily running ATR43G3 .82 turbine on 18psi.
Also for Actuator DIY people. This is a alternative method of getting 12psi without boost controller. I've personally managed 14psi tops. This extender arm is for $25 for who ever needs it. You need to cut and thread factory actuator’s connection rod to get it installed.
This is a reading out of a PU high flowed turbo in Max power profile based in .82 bolton turbine housing. Made 290rwkws on 19psi. The car's dyno tuned straight turbo installation which is supposedly to be tuned after 200KMs of driving. So the actual curve should be shifted by 300RPM or 8.5KM/H to the left after run in.
I think it can squeeze out another 30kws on 22psi. Customer's very concert about his engine so we left as it is.
Its a 95 R33. Car's got PFC, 550cc injectors, Z32 AFM, 3inch exhaust, cooler and usual stuff.
So 300rwkws on stock comp housing that looks EPA legal is achievable.
Very nice, so is this the ATR3G4 wheel? Or is it similar to the 3576 like I have ordered?
So what is the advantage of running the atr43 if this is hitting 290kw? What revs did this hit full boost at?
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
